Original Oem Tape Seal For Light Lenses
Posted 21 January 2014 - 08:02 PM
Posted 21 January 2014 - 08:40 PM
I used a roll of 3m double sided that's sold as outdoor capable.
In combination with black silicone to watertighten the edge between lense and cluster, it's been fine so far (2 years).
I do garage it, and try to avoid rain in total, so i may not be a fair comparison for an outside sleeper trying this.
But with oem also being double sided tape, how bad could it be? (ie, some tiger seal constructions have also lost lenses)
Downside is that you get one chance of getting the lense on the cluster correctly, as it will not move a mm once stuck.
Edited by smiley, 21 January 2014 - 08:46 PM.
Posted 21 January 2014 - 08:42 PM
Posted 21 January 2014 - 08:49 PM
I used the Black sticky string that EP sell for Elise front lens after probs with Tiger seal type products.
Posted 21 January 2014 - 08:55 PM
Posted 21 January 2014 - 09:00 PM
Posted 21 January 2014 - 09:03 PM
Problem I've found with sealing the edge is when you come to fit and tighten the light it's pulls the lense slightly breaking the seal.
Have not encountered that problem with double sided tape in combination with sealant (ie it does not bodge when tightening the rear nut)
I was off by 2mm with the lense, and now i have a gap between cluster and clam i cannot correct, without doing it all over.
Winterjob. (and putting those fairylight leds in)
Posted 21 January 2014 - 09:10 PM
Totally water proof, you can stack it and as soon as it touches itself it might as well be one piece. just be aware if you let any squeeze out the sides you will need to clean it all up before fitting the light. Also I would try to have the lights warm when you bolt it in to let it settle faster. I just did mine on a sunny summer day.
In my experience Tiger seal does not actually bond them, and just peels away. I nearly lot a lens with it so moved to this about 5 years ago and never touched it again.
It is also easy to mold in to any shape you want so I also used it to plug the holes in the backing plate. I used to used it to insulate and waterproof PC's running -70 c.
I believe 3M is the best one but EP is reasonable price and 3M anyway.
Edited by Crabash, 21 January 2014 - 09:13 PM.
Posted 21 January 2014 - 09:13 PM
Posted 21 January 2014 - 09:16 PM
Never checked on the make of the amazon one just go for a the 3M version where ever you get it. If in doubt get at EP.
Edited by Crabash, 21 January 2014 - 09:16 PM.
Posted 21 January 2014 - 09:40 PM
I also used that 3M product and works very well.I used the Black sticky string that EP sell for Elise front lens after probs with Tiger seal type products.
Edited by xco, 21 January 2014 - 09:43 PM.
Posted 21 January 2014 - 10:56 PM
just done my lights today,and had used way to much tiger seal as it was on the inside...bummer,but 5 mins in the oven and it was off again and redone..hellish sh*t the tiger seal,haven,t put the lights back on the car yet because i am fitting h1 and h7 and clam will be coming off to fit the carbon v this weekend..i have all the bolts off except the ones in the bracket at the top of the doors,need to get my mate over to remove it..getting there tho.
Posted 23 January 2014 - 06:41 AM
Posted 14 February 2016 - 03:21 PM
Edited by Goose, 14 February 2016 - 03:22 PM.
Posted 14 February 2016 - 03:44 PM
Posted 14 February 2016 - 04:21 PM
Edited by Goose, 14 February 2016 - 04:22 PM.
