Hi Friend,
My VX220 got flat battery.
I noticed the battery location is not that easy for jump start.
May I know is there any easy way to jump start my VX220?
I have the cable and battery.
Thanks!
Adrian
Posted 17 February 2014 - 07:08 PM
Hi Friend,
Thanks!
Adrian
Posted 17 February 2014 - 07:10 PM
be carefull u may blow the ecu
do a search and find the correct way to do this
it may be safer to extract the battery and charge it or replace it with a new one
I have had a blown ecu due to jump starting I can't explaine why or how just that I did !
Posted 17 February 2014 - 07:16 PM
Posted 17 February 2014 - 07:46 PM
Posted 17 February 2014 - 07:52 PM
Posted 17 February 2014 - 07:56 PM
me too and I'm electrically trained ...but it's what happened to me when I got jumpstarted at home by the AA a few years back
Ireally wish U could understand it
I don't know if its an ignition on or off type thing
but basically the car went flat
the aa jump started it
that failed
it went to dealers
then needed new ecu
Posted 17 February 2014 - 08:09 PM
I had a flat battery last year and my trickle charger wouldn't bring it back to life. I left it over night on normal charger and it came to life. I have also bump started a few VX's with no issues.
Posted 17 February 2014 - 08:16 PM
AFAIK, it's to do with disconnecting the jump leads. The car with the flat battery sees the massive drop in voltage when the leads are removed, which can result in the alternator producing a spike in voltage which can fry the sensitive components.
My beemer has jump start points which protect against this.
Edited by Gedi, 17 February 2014 - 08:17 PM.
Posted 17 February 2014 - 08:31 PM
Posted 17 February 2014 - 08:51 PM
On some of our trucks you have to keep the slave lead connected for about half an hour after jumping a dead vehicle to protect the dead vehicles alternator. Similar thing?
Posted 17 February 2014 - 09:01 PM
I believe the ctek needs to detect some minimum voltage to start trickeling.
A way to trick it is to connect the dead battery to a full one, attach the ctek, and when it starts to trickle, remove the wiring to the full battery.
Posted 17 February 2014 - 09:08 PM
Voltage drop (and load change) will be less than a battery terminal coming loose, which whilst it hasn't happened to me I understand it does happen. Not doubting it happen(s) just can't get my head round how!It won't be a voltage drop as the alternator will be kicking out about 14v. However there will be a change in load on the alternator when the jump start battery is removed. I'm just pondering the implications of load change.....
Edited by Chris P Duck, 17 February 2014 - 09:17 PM.
Posted 17 February 2014 - 09:28 PM
When the good battery (+ alternator) providing 14v is disconnected, the alternator on the flat vehicle can create a voltage spike as it tries to compensate for the huge increase in load.
It's called a load dump http://en.wikipedia.org/wiki/Load_dump
Posted 17 February 2014 - 09:29 PM
Posted 17 February 2014 - 09:56 PM
I jumped started mine yesterday, which would of been about the tenth time I have used the jump leads to start it. Had no issues so far.
1) Just make sure the cables don't touch the chassis.
2) Make sure ignition is off whilst connecting cables up.
The vehicle I use to jump start I don't have the engine running. Don't know if that makes a difference.
Battery is now connected to c-tec, a bit late I know.
Posted 17 February 2014 - 10:40 PM
Edited by ghand, 17 February 2014 - 10:42 PM.
Posted 18 February 2014 - 07:52 PM
Posted 18 February 2014 - 08:33 PM
Posted 19 February 2014 - 06:43 PM
