Lotus Elise S2 Will Not Start! Ideas?
Posted 20 February 2014 - 07:59 PM
Posted 20 February 2014 - 08:02 PM
Sounds like it could be immobiliser related?
Posted 20 February 2014 - 08:06 PM
Same, if it runs for the exact same time each time it starts, it sounds like an immobiliser problem. Would explain why easy start etc won't make a difference.
Diagnostic may confirm depending on the ECU/Software used
Sometimes accompanied with a flashing eml on certain vehicles although I have no experience of the S2/Toyota engine management so would rely on it.
Posted 20 February 2014 - 08:08 PM
As above, if I use my spare key to start my vx it does exactly this. So I would say as above and have the immobiliser checked out.
Or try the spare key.
Posted 20 February 2014 - 08:14 PM
Posted 20 February 2014 - 08:16 PM
It will usually do exactly as you have described, either briefly start and then cut out or in some cases endlessly give a healthy turn over.
Posted 20 February 2014 - 08:17 PM
Posted 20 February 2014 - 08:22 PM
Posted 20 February 2014 - 08:27 PM
Seloc?
Thought the same but I don't think he uses forums, thought someone on here would have some knowledge though!Seloc?
Posted 20 February 2014 - 08:28 PM
Posted 20 February 2014 - 08:38 PM
Vx owners know more about cars anyway. Lotus owners are bellends.Thought the same but I don't think he uses forums, thought someone on here would have some knowledge though!Seloc?
Posted 20 February 2014 - 08:43 PM
Try pressing and holding both buttons on the immobiliser fob for 10-15 seconds. When they are drained they can loose comms with the ecu and need relearning.
Posted 20 February 2014 - 09:01 PM
Posted 20 February 2014 - 09:40 PM
The Elise is different to the VX. Instead of a proximity based/chip setup you just have a fob that sends a rolling code to the ECU a bit like a garage door or whatever.
You can bypass the immobiliser quite easily but you'll have to PM me if you need that info.
Posted 21 February 2014 - 02:05 AM
Sell rubbish non startin Lotus, use the mon ey to buy a super cool hard rockin VX220.
Not he most useful of answers but just back from the pub in, I want ot go to bed but th e misses is in the shter and I have decided to disperse my wisdom. What i says goes.
Posted 21 February 2014 - 02:40 AM
Haha someones going to be feeling it in the morning!!
Posted 21 February 2014 - 08:14 AM
on my s2 elise if the key fob button is not pressed it will not even turn the engine over so it seems odd it starts then dies
Edited by Thealastair34, 21 February 2014 - 08:14 AM.
Posted 21 February 2014 - 08:41 AM
fuel pump dead?
Posted 21 February 2014 - 09:45 AM
