Headlight Issue - Need Help Pls
Posted 21 February 2014 - 05:45 PM
Posted 21 February 2014 - 05:59 PM
I am clutching a straws slightly and am certainly no auto-electrician but...
One would assume that the fuse is rated such that if there was a short, it would blow the fuse rather than bugger the switch... but maybe...
Short blew sidelight switch
Replaced sidelight switch, short blew it again
Replaced sidelight switch with headlight switch, blew that too
Could be total utter rubbish but...
Maybe disprove me by swapping the headlight switch out for the foglight switch... if that works... then maybe I ain't so daft?
Edited by Ormes, 21 February 2014 - 06:00 PM.
Posted 21 February 2014 - 06:11 PM
Posted 21 February 2014 - 06:16 PM
I had persistent issues similar to what you describe, it was all down to a dodgy earth connection on one of the dipped beams. The heat affected the spade connection and melted part of the wire. Sometimes pulling the spade out and reconnecting it would fix it.
I put in HIDs, and the problem hasn't recurred.
Posted 22 February 2014 - 01:25 PM
Posted 22 February 2014 - 01:32 PM
Posted 22 February 2014 - 01:40 PM
Posted 22 February 2014 - 02:28 PM
Posted 22 February 2014 - 03:45 PM
