Harness Anchor Points
16 replies to this topic
#1 Kart59
Kart59
  • 298 posts
Posted 25 February 2014 - 05:23 PM
Hi all, I've fitted a tillet b5 seat with eb1 fixed mounting brackets, took a whole day faffing around to get it as low and as far back as possible, got there in the end. Question, what would be a good way of anchoring a harness on either side? Aso I know I need a harness bar, has anyone got any pictures close up of the clearance between back of seat/bar/car as I don't reckon I will be able to keep the speakers in mine as the seat is so far back.
#2 Kieran McC
Kieran McC
  • 3,416 posts
Posted 25 February 2014 - 05:31 PM
I have just mounted mine six point harness from the Lotus Motor sport instructions , Drill through the floor each side of the rear floor mounting bolts, Add a spreader plate screw on the eye bolt .
There are the full instructions on here some where I cant find them LOL
#3 Kart59
Kart59
  • 298 posts
Posted 25 February 2014 - 05:36 PM
Thoseinstruction would be perfect lol! I'll keep looking then....
#4 Kieran McC
Kieran McC
  • 3,416 posts
Posted 25 February 2014 - 05:38 PM
It was round December 2013
#5 Kieran McC
Kieran McC
  • 3,416 posts
Posted 25 February 2014 - 05:40 PM
Its under fitting Lotus Motor Sport seat tunning and mods
#6 sworks
sworks
  • 1,566 posts
Posted 25 February 2014 - 06:21 PM
I have a b5 with fixed mount. Will try and get some pics for you (won't be until the weekend though I'm afraid).
#7 Kart59
Kart59
  • 298 posts
Posted 25 February 2014 - 06:32 PM
That would be useful if you could sworks.
#8 Kart59
Kart59
  • 298 posts
http://www.billswebs...ointHarness.pdf This the guide then Kieran?
#9 Kieran McC
Kieran McC
  • 3,416 posts
Posted 25 February 2014 - 06:37 PM
thumbsup
#10 sworks
sworks
  • 1,566 posts
Posted 25 February 2014 - 06:41 PM
No worries. If you have the seat as low and far back as it will go (depending on how much you have it reclined) you will need the Jon betts track day bar. This means you will have to remove the speakers (I have the whole shelf u it removed). You'll also notice that there is absolutely no clearance at all between the seat and the floor (as the seat has a large rounded extrusion). I wanted to use a crotch strap but couldn't see a way of fitting.
#11 Kart59
Kart59
  • 298 posts
Posted 25 February 2014 - 06:58 PM
Have you looked at that guide for the crotch strap fitting?
#12 sworks
sworks
  • 1,566 posts
Posted 25 February 2014 - 07:01 PM
No I haven't. Stef at BoT fitted my lap straps as I was a little unsure how to mount them
#13 Kieran McC
Kieran McC
  • 3,416 posts
I didn't use that guide for the crotch straps ,Just spreader plates and eye bolts through the floor.
#14 sworks
sworks
  • 1,566 posts
Posted 25 February 2014 - 07:05 PM
Just had a quick look. The only thing that springs to mind is the lack of space. I had to leave the hand brake and gear leer shroud out as the bolts for the mount/seat fouled the tunnel
#15 sworks
sworks
  • 1,566 posts
Posted 25 February 2014 - 07:06 PM
There isn't enough room under my seat for eye bolts. The seat is almost in the floor
#16 Kart59
Kart59
  • 298 posts
Posted 25 February 2014 - 07:12 PM
You don't have eye bolts under the seat for the crotch strap, it bolts to the floor and the horizontal chassis brace ( the bit you stand on when getting in) the low bit of the seat is much further back. As picture 5 in the guide, I reckon you would get one in. I was looking at race prepped Elise's last weekend and their seats were low and had no problem with crotch strap mount.
#17 Kieran McC
Kieran McC
  • 3,416 posts
Posted 25 February 2014 - 07:20 PM
The top of the crotch strap eye bolts are below the front edge if that make sense. My drivers seat is mounted on the OEM seat runner ,it sits low there is plenty of clearance.
