http://jalopnik.com/...gine-1529865968
I bet it's going to take a while before you have this option on the ODBTuner.
Posted 27 February 2014 - 08:46 AM
Posted 27 February 2014 - 09:20 AM
Looks like the future. I've seen various camless designs in the past, each with their own pro's and cons but this seems to have got a lot further than the others.
Posted 27 February 2014 - 09:39 AM
Longevity will still be the critical factor with this. It's difficult to lubricate pneumatic parts and the valve train is a key wear area as it is, this might mitigate the wear, it might make it much more severe depending on implementation.
What really needs to happen is a large manufacturer to buy them and initially uses the design to drop fleet average CO2.
Posted 27 February 2014 - 10:00 AM
I watched a video on this a few months ago, certainly looks to be the way forward.
Posted 27 February 2014 - 10:01 AM
One of the versions I saw had no valves either. It was an odd design. Imagine a babybel in the port with a hole bored through it off-centre. This was turned instead of a cam essentially opening the port / closing the port as a tube rather than a valve. Similar to a ball valve on domestic plumbing. I imagine this was lubricated like a cam??? the problem with this design was sealing it. They had some odd seal arrangement which was never really revealed so, given I've seen nothing of it, I suspect its not practical.
Posted 27 February 2014 - 10:13 AM
Isn't that similar to a sleeve valve?
Posted 27 February 2014 - 10:53 AM
Yes, similar. Looks like a camshaft with holes through it so slightly more conventional looking but the principle is the same
Posted 27 February 2014 - 11:32 AM
Interesting, the Fiat Multiair uses only cams to control air , there is no throttle butterfly. But it still has cams, albeit with a solenoid valve as a hydraulic/mechanical link of the cam's profile.
Posted 27 February 2014 - 11:37 AM
Posted 27 February 2014 - 11:45 AM
exhaust cam is conventional, its just the inlet cam hydraulic that has the extra solenoid control
Posted 27 February 2014 - 11:47 AM
That makes sense, the inlet cam is the mildest in terms of wear so it looks like there could well be durability issues with going to a full solenoid valve train. I'd be interested to see how long these twin air engines last.
Posted 27 February 2014 - 11:54 AM
Edited by techieboy, 27 February 2014 - 11:55 AM.
Posted 27 February 2014 - 12:03 PM
what happened to the VX with the variable valve head?
Posted 27 February 2014 - 12:06 PM
interesting site with lots of upgrade info , seems to cover most of the ecotec variants
http://www.fmsrperfo...ory&path=20_124
Posted 28 February 2014 - 09:40 PM
