Fezzasus Heaters - Mk2.8, Rhd And Lhd
Posted 01 March 2014 - 07:09 PM
Posted 02 March 2014 - 12:47 AM
Posted 02 March 2014 - 12:17 PM
5 of the first ten provisionally spoken for.
Posted 02 March 2014 - 01:06 PM
Posted 02 March 2014 - 04:21 PM
There was a 2.7, briefly.
MK2 is still the basic form it's in now, but has an exposed PCB (controller for the temp. solenoid) which could fail in harsh conditions
MK2.5 moved to using a potted PCB to make the PCB weatherproof, also made it easier to install by having open holes for the radiator to bracket bolts and a plug on the cable from the cabin. Radiator also moved to half height, but 4 x fin density to increase response time when temperature is changed.
MK2.6 addressed another weakness - the temp. solenoid itself (first supplier solenoids were fine, they couldn't supply any more so I bought some from a different supplier that appeared the same, however a couple of failures lead to me buying OEM parts at 4 x the price)
MK2.7 changed the tapped holes in the bracket for threaded inserts for greater durability.
Now we're at 2.8, which is certainly the final iteration. This combines the different designs for the RHD and LHD models into one bracket. It also (unfortunately) uses a solenoid that costs even more than my previous supplier of OEM parts as they can no longer supply.
Posted 04 March 2014 - 01:48 PM
Posted 04 March 2014 - 01:54 PM
Posted 04 March 2014 - 02:07 PM
Right, I think by my maths that's the first batch of 10 accounted for. 2nd batch not in production yet but will be as soon as all the 1st batch are out.
Posted 05 March 2014 - 10:47 AM
Edited by jfalesi, 05 March 2014 - 10:48 AM.
Posted 18 March 2014 - 12:04 AM
Just taken my OEM heater out to do some maintenance because the flap had stuck. Even though I must be lucky as my heater does generate a decent amount of heat, it was a major an arse to get out and such a poor design only destined to fail, that I'm loathed to put it back in!
Please can you put me down for a RHD heater from your next batch?
Posted 18 March 2014 - 07:20 AM
Me too :-)
Posted 18 March 2014 - 08:06 AM
Okay, i'm going to place an order for the next/last batch tomorrow. Will keep you updated.
Posted 19 March 2014 - 07:26 AM
Hi Tom, just wondering when you will be posting out the first batch? It's still cold you know! ;0)Okay, i'm going to place an order for the next/last batch tomorrow. Will keep you updated.
Posted 19 March 2014 - 12:45 PM
They're gone, i just need to sort through tracking numbers.
Posted 19 March 2014 - 01:38 PM
Superb! Thanks Tom. Can't wait to fit it.They're gone, i just need to sort through tracking numbers.
Posted 25 March 2014 - 08:37 PM
Would it be possible to have my tracking number Tom? It still hasn't turn up since I pm'ed you the other day so we need to track it down. Thank you.They're gone, i just need to sort through tracking numbers.
Posted 27 March 2014 - 04:46 AM
Posted 27 March 2014 - 08:13 AM
Shipping to Sweden is £56! If that is okay then I can wait until the 6th of April.
Posted 27 March 2014 - 10:17 AM
Posted 31 March 2014 - 12:55 PM
