New Disc And Pads Brake Best Configuration?
9 replies to this topic
#1 Matteo21
Matteo21
  • 73 posts
  • Interests:Motorsport - Design
Posted 06 March 2014 - 12:53 PM
Hi all
I try new brake discs and pads for my VX220 (For Used Road and Track Day)
The new composition of my brake system is: Front AP Racing Caliper 2 Pot -Disc brake 308mm (Vauxhall Astra OPC)
-Spacer Rear
-AP Racing Caliper 2 Pot with spacer -Disc brake 288mm
For Disc Brake,
-EBC Ultimax
-EBC Blade
For Pads:
1° Configuration
Front Mintex M1155 / Rear Mintex M1144
2° Configuration
Front/Rear Brembo HP2000
3°Configuration
Front CL RC6 / Rear CL RC5
what do you think?
#2 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 06 March 2014 - 01:17 PM
2 pot front & rear???
#3 slindborg
Posted 06 March 2014 - 01:26 PM
the brake pad will overlap the outside edge of the 308mm discs (plus they weigh a sh*t load.... nearly double that of the 288's) so you wont get the full use of the pad. Also imho it made next to sod all difference in the braking anyway.
4th config.
standard 288mm discs front and rear, Performance Friction Braking 97 spec (or 01) pads. Done. Face on windscreen :)
#4 Matteo21
Matteo21
  • 73 posts
Posted 09 March 2014 - 11:09 AM
ok best 288 front and rear. for brake discs
-EBC Ultimax
-EBC Blade
#5 Bargi
Bargi
  • 4,483 posts
Posted 09 March 2014 - 12:17 PM
CL RC6 all round
#6 scw02102
scw02102
  • 1,581 posts
Posted 10 March 2014 - 12:31 PM
Getting new discs and pads fitted tomorrow
What breaking in what do you guys do? Im running Mintex 1144
In the past with brembo I have done the recommended
50mph-5mph hard break, then
60mph-5mph hard break, then
70mph-5mph hard break
all in one go to keep the heat high
to burn the layer off the discs and help settle the pads
#7 JG
JG
  • 13,617 posts
Posted 10 March 2014 - 12:36 PM
You need to be more gentil with new discs.
ligh braking first to warm them up evenly then do the hard stuff.
#8 slindborg
Posted 10 March 2014 - 12:40 PM
Mintex have a document somewhere online with their bedding in procedure for [color=rgb(255,0,0);]BRAKES[/color]
#9 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 10 March 2014 - 01:03 PM
[color=rgb(255,0,0);]LINK?[/color]
#10 slindborg
Posted 10 March 2014 - 01:10 PM
www.google.co.uk
