Gaz Monos
15 replies to this topic
#1 Kart59
Kart59
  • 298 posts
Posted 08 March 2014 - 07:07 PM
Has anyone recently fitted a set of Gaz Monotube 40mm shocks?
Thinking of getting these....after considering nitron, ohlins, etc numerous times. however i need to save some money as i need some paintwork done.
Thinking of the gaz over the quantum as i can play with the rebound settings, ay thoughts?
#2 peteslag
peteslag
  • 920 posts
Posted 08 March 2014 - 07:31 PM
I went for the Quantum zeros, absolutely no regrets. Mind you, if I had adjustments all I would do is twiddle with them constantly. That was the main selling point of the Zeros for me (that and the fact that they are a bit cheaper).
#3 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 08 March 2014 - 07:47 PM
I have gaz monos on my vx. I can recommend them. Really nice ride and less bumpy than bilsteins.
#4 Paulus H
Paulus H
  • 2,063 posts
Posted 09 March 2014 - 01:21 AM
My Gaz are fine. I think the crucial issue you should be concerned with is what springs to specify. Track day stiff and you will be losing out on grip for the road, too soft and you will be losing out on track. The other key factor is the extension you specify. Long throw dampers good with softer springs or helper springs. Short throw better for hard springs and low ride height. But not that straight forward - a long story.......... Ah suspension... no easy answers Kind regards, Paul
#5 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 09 March 2014 - 08:08 AM
I have gaz monos and theyve beeen great. I have 550lb rear and 450 front springs.
Martin S
#6 YorkieAndrew
YorkieAndrew
  • 242 posts
  • Interests:Seeking my 18 year old balls, DIY Landlord/Retailing slave, Politics (love a debate), Yorkshire Tea & a buttered Teacake
Posted 09 March 2014 - 10:14 AM
Excuse my ignorance - are gaz mono's, gaz gold pro's?
#7 JG
JG
  • 13,617 posts
Posted 09 March 2014 - 10:16 AM
No, they are different.
Mono's are like a Nitron NTR in construction.
#8 xco
xco
  • 62 posts
Posted 09 March 2014 - 10:20 AM
Elise-shop description says that rear dampers are mounted with helpers, but my fastroad-trackday setup gaz monos haven't got them. In any case to need them you have to lower the rear more than 5cm. However, on 120mm height (with oem tyres) in the front, the springs have zero preload on full extension... Are the helpers only fitted for the race setup?
Edited by xco, 09 March 2014 - 10:22 AM.
#9 Paulus H
Paulus H
  • 2,063 posts
Posted 10 March 2014 - 12:46 AM
Mmm I think that is because there are or were 2 lengths of damper. Short stroke for low cars that did not want to tit additional helpers. And long stoke for std ride height or lowered with helpers. Please note "I think". Kind regards, Paul
#10 xco
xco
  • 62 posts
Posted 12 March 2014 - 01:24 PM
Yvo has told me that only were fitted in the old race setup but now none version is fitted with them.
#11 fezzasus
Posted 12 March 2014 - 02:53 PM
And like a trifle in materials.
#12 Kart59
Kart59
  • 298 posts
Posted 12 March 2014 - 04:10 PM
No, they are different.    Mono's are like a Nitron NTR in construction.
Can you elaborate on this, examples etc? As I was going to buy some tonight...
#13 chris_uk
Posted 12 March 2014 - 04:21 PM
Just google monotube vs twintube design.
#14 Kart59
Kart59
  • 298 posts
Posted 12 March 2014 - 04:44 PM
I was referring to the trifle comment about materials. Had my mind set on a pair of gaz monos after going through every other brand first....tough decession this!
#15 Kart59
Kart59
  • 298 posts
Posted 12 March 2014 - 05:02 PM
#16 fezzasus
Posted 12 March 2014 - 05:17 PM
Gaz don't have the best record for durability. The monos may well be better, but that could also be down to them being a newer design and therefore lower numbers and younger examples that aren't showing problems yet.
I went for Nitron because I didn't want to gamble with the durability of Gaz, others may well opt to same some money by going with Gaz with the acceptance that they may have to send them off for refurb/repair.
