Hi Hope someone can advise
I Have a small piece of fiberglass which has broken away - To try and explain - It is underneath where the undertray fastens through the shear plate - Basially there is a hole in the edge of the fiberglass where a spire clip fits over - The bolt then goes through the undertray and shear plate and into the clip - Now the problem is the hole in the fiberglass is no longer a hole as a thin piece has broken away - I want to attempt to repair - Is it best to try and reattach with some resin or to just build it back up and redrill the hole
Many thanks - Tony
