Evening all, being quite new to the forum i feel the need to introduce myself before asking for help. Two years ago i brought my first High Mileage VXT, i soon decided that it needed to be modified so i opted to buy a car with lower miles. Last April i brought my Red CS Stage 2 VXT from Dan Robinson, since then the car has undergone the following modifications:
- Nitron Coilovers
- TD 1.2's 17/16 combo
- TMS rear CF diffuser
- Robin Front Splitter (recently fitted after respray)
- Fog light brake cooling mod in progress
- MMG rear wing (not yet fitted, wing struts are currently being welded by Pro Alloy)
- JK Composite Seat with modified drivers sub frame
- Custom Harness bar
- Apexi Air Filter
- Pro Alloy Hard Intake Pipe
- Pro Alloy Gear Box Breather
- Pro Alloy Radiator
- Pro Alloy Charge cooler
- Courtenay Sport Enlarged Plenum with Pipework
- VXR Turbo (not yet fitted)
- VXR MAF (not yet fitted)
- VXR Injectors (not yet fitted)
- Front Clam Respray (this is yet to be mopped and now the rest of the cars paint needs restoring)
I will be purchasing a Courtenay Sport Uprated Clutch next month and then its time for CS stage 4.
HOWEVER, i am having issues with my Robin splitter, it was fitted last week and i love the way it looks. The problem is occurring at high speeds, when the car gets over 100 mph the rear end begins to lift and the splitter is catching the road! I know plenty of members have these splitters fitted with no issues which points the blame at how i have installed it. My heights are currently 95/120, (i am yet to have my suspension set up so please hold the abuse). I still struggle to believe this is the fault. I have fixed the splitter using 5 M8 bolts with penny washers using the guide on the forum with the bolts being located 145mm from the front face. Is this wrong?? I would like to get this issue sorted before having the splitter repaired. Below are pics of the car and damage. Cheers in advance, J.
