Mk2 Post Cat Lambda Cheater
trumpet cheater lambda postcat
93 replies to this topic
#1 slindborg
Posted 09 April 2014 - 10:51 AM
Roll up, Roll up...
I have put together 10 fully tested MK2 versions of the famed Slinderella Motorsport Post CAT Lambda cheater. There are a further 9 on the bench but they are untested as of now and I will post when they are ready.
Due to work stuff, I will only be able to post from Monday 14th April, but giving you all the heads up if you wish to get one.
Quick info:
MK2 cheater with resistor = £27.50 (inc postage)
MK2 cheater without resistor = £25.00 (inc postage)
I take paypal , cash and maybe Raspberry Pi's :lol:
Will work with both NA (inc SC) and Turbo
For those of you with a MK1 cheater running etc, this is functionally NO different, just had a slight redesign due to obsolete parts and reducing the size of the board. There is no reason to upgrade/change.
Long winded info:
If you dont know what the cheater is for then this is for you:
The emisisons regulations for our cars state that there must be a test to see if the Catalyctic convertor is a) present and b.) functioning... and if its not doing either of those then throw on the EML. The etst is carried out with a second lambda sensor after the CAT to detect that there is slightly different exhaust gas to that of the first sensor.
 Now the actual causes for the EML to come on can be faults with the second sensor (common) or in reality the removal of the CAT for POWWAAAHHHH.
The cheater will enable you to get rid of the fairly unreliable sensor, and should you be of the sort, to remove the CAT.
The first 10 can come with the resistor to act as the heater, they will need to be mounted somewhere with airflow, and a good metal surface to bolt/rivet to as even something as lowly as 9Watts will heat up a 25Watt resistor on an extra heatsink, in no time!!! You can alternatively just use the existing lambda sensor heater, assuming its not that bit that has failed. After the 10 Resistors have gone, I will NOT be supplying them as they are easily available from the likes of CPC (who have no delivery charges).
DO NOT buy power resistors from EBAY!!!!
I think thats everything.
#2 FLD
Posted 09 April 2014 - 01:17 PM
Ooooooh, can I buy a resistor from you?
#3 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 10 April 2014 - 12:19 PM
With it being a Motorsport part, i had better get one! Also, I have an EML on for a duff post cat sensor. I think it is a problem with the heater element so I guess I need one with a resistor.
Wanna fit it for me?  :) like the good old days  :D
#4 slindborg
Posted 10 April 2014 - 12:25 PM
Only if I can have a ride on KN0B
#5 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 10 April 2014 - 03:04 PM
Fo shnizzle. Got the old girl out of 5 months hibernation yesterday and using it daily this week  :tt:
Will have to arrange a time and place over the next few months. The EML wont be affecting the fueling etc will it?
#6 The Batman
Posted 10 April 2014 - 03:06 PM
I will take one transborg
#7 slindborg
Posted 10 April 2014 - 03:14 PM
Nope, no affect on fuelling at all.
I'm not sure, but I think an EML/MIL lit is atleast an advisory, if not a fial for the MOT these days.
#8 johnathan
johnathan
  • 405 posts
  • Interests:Snowboarding,cars
Posted 10 April 2014 - 05:50 PM
Dibs for one too please? What's the preferred method of payment?
#9 johnathan
johnathan
  • 405 posts
Posted 10 April 2014 - 05:53 PM
Resistor option please, and I am a tool for not reading before getting excited about buying bits for my car and ploughing on!
#10 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 10 April 2014 - 06:03 PM
I'll have a resistor one. Let me know how you want the money ;)
#11 CraigyT
CraigyT
  • 119 posts
  • Interests:Track driving.
Posted 11 April 2014 - 02:02 PM
Ill have one with resistor please! can paypal.
#12 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 11 April 2014 - 03:42 PM
Stu, can I take a MK2 with resistor and if I sent you the plug, can you make it plug and play as my MK1 effort doesn't work?
#13 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 11 April 2014 - 03:57 PM
I have mine sitting here now Mike if you want.
#14 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 11 April 2014 - 05:05 PM
Cheers Luke, I will still want a MKII Slindy version though.
#15 vx220bass
vx220bass
  • 117 posts
Posted 11 April 2014 - 06:22 PM
I will take one with Resistor if you still have any left Thanks
#16 Cereal Killer
Cereal Killer
  • 81 posts
Posted 11 April 2014 - 06:54 PM
Are they easy to fit, how do you do it?
#17 Cereal Killer
Cereal Killer
  • 81 posts
Posted 11 April 2014 - 09:54 PM
You know what, I'll take one with the resistor please and worrying about fitting when it arrives.
#18 slindborg
Posted 12 April 2014 - 07:25 AM
Send the mk1 one back too please :) I will check it over and send that out aswell.
#19 Asheey
Asheey
  • 550 posts
  • Interests:Cars, Bikes, Women and Beer.
Posted 12 April 2014 - 08:39 AM
Ill have one with resister please.
#20 Dan r
Dan r
  • 666 posts
Posted 12 April 2014 - 09:29 AM
Could I have one with resistor as well please.
Also tagged with one or more of these keywords: trumpet, cheater, lambda, postcat
