Diy Sos
Posted 18 April 2014 - 06:31 PM
Posted 18 April 2014 - 06:48 PM
Laminovas were worthy of a clean!!!!!
Posted 03 May 2014 - 03:19 PM
Can someone confirm that I have these the right way around:
Also, is there anything I should consider/do before I put them back and bolt everything down?
Posted 03 May 2014 - 03:41 PM
Correct for the dual pass, only the orientation of your cores is a bit off. Try to allign the bigger slots of the cores with the air in /out gaps in the manifold...
Posted 03 May 2014 - 04:06 PM
Posted 03 May 2014 - 04:16 PM
Thanks
Posted 04 May 2014 - 09:40 AM
Line these up with the inlet and outlet within each chamber of the manifold?
Posted 04 May 2014 - 12:26 PM
Yes
Laminova spec the same installation orientation when used in their oil/water heat exchangers so the wide 'channels' are used as the in- and outlet sides.
The idea is that the wide slot is used to channel the air towards the fins where it will result in a laminar flow between the the fins (and trapped between the core and the housing) to the other side (least resistance) and exit out the other side again.
Posted 04 May 2014 - 12:59 PM
Posted 10 May 2014 - 08:25 PM
Looking for plugs and boots to suit the LEH injectors I have.
Courtney sell these: http://www.courtenay...c/prod_812.html
Also found these: http://www.ebay.co.u...=item2a2856a54a
Are either or both of these correct?
Cheers
Posted 13 May 2014 - 08:33 AM
Both are correct, however standard JPT connectors may need trimming down to fit while the Courtney ones will fit out of the box. You will also need a 5th one if you intend to run a Bosch charge cooler pump (other brands may use different connectors)
Posted 13 May 2014 - 10:44 AM
Thanks Tom. Ended up ordering from Courtney anyway.
Yes I am using a Bosch, didn't realise I needed one for this. Will have to see if i can get a random single set from ebay.
Thanks
Chris
Posted 13 May 2014 - 10:50 AM
Posted 13 May 2014 - 11:19 AM
Ev1 plug.
Posted 15 May 2014 - 01:26 PM
Ordered a Contitech belt and have had a Dayco belt delivered.
Is there much difference between the two makes i.e should i just stick with the Dayco belt, or send it back and ask for the Contitech belt?
Posted 15 May 2014 - 01:29 PM
Posted 15 May 2014 - 01:42 PM
Thanks.
So guess I'll just see how the Dayco belt goes.
Haven't seen these mentioned too much, so wasn't sure if they were as much use as an elastic band
Posted 15 May 2014 - 01:51 PM
Posted 15 May 2014 - 01:57 PM
Brand new one ready to go on (if I ever get around to starting this , or more importantly, I am actually capable of finishing it)
