Ticking Noise Coming From Engine?
20 replies to this topic
#1 02richt1
02richt1
  • 15 posts
Posted 20 April 2014 - 12:03 PM
Right guys,,
i was wondering if anyone could give me some advice ... on start-up and all through the rev range there is a ticking noise coming from the engine bay and it gets louder with the revs of the engine,, ive made a video of it ... http://youtu.be/7JppijIBgto  any advice as to what it could be would be appreciated muchley :)
#2 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 20 April 2014 - 12:10 PM
scrap that, can see is a turbo from video.
Edited by Boombang, 20 April 2014 - 12:12 PM.
#3 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 20 April 2014 - 12:11 PM
Just seen it's a turbo on the video, sounds like a hydraulic lifter to me.  Have you checked the oil level?
Could also be a lose spark plug, they should be pinched up (can't remember the torque setting) rather than ballsed up FT but shouldn't be lose.
Check the plugs first IMHO, but then can you not work out roughly where the noise is from?  These noises rarely get captured well on video, it could be from under the cambelt or from the exhaust side.
If not the plugs and inside the head, use a long screwdriver pressed to your ear against different places on the engine to ID where it is coming from.
Edited by Boombang, 20 April 2014 - 12:15 PM.
#4 CocoPops
CocoPops
  • 17,177 posts
Posted 20 April 2014 - 12:15 PM
Or noisy injectors?
#5 J4EY D
J4EY D
  • 3,236 posts
Posted 20 April 2014 - 12:18 PM
Or noisy injectors?
:yeahthat:
Was my first thought
#6 RabnaKS
RabnaKS
    If anyone can talk Bllx, I can!💣
  • 2,717 posts
  • Interests:MTB, VX220, oh & cars, golf, sarcasm with humour!
Posted 20 April 2014 - 12:22 PM
Just seen it's a turbo on the video, sounds like a hydraulic lifter to me.  Have you checked the oil level?   Could also be a lose spark plug, they should be pinched up (can't remember the torque setting) rather than ballsed up FT but shouldn't be lose.     Check the plugs first IMHO, but then can you not work out roughly where the noise is from?  These noises rarely get captured well on video, it could be from under the cambelt or from the exhaust side.   If not the plugs and inside the head, use a long screwdriver pressed to your ear against different places on the engine to ID where it is coming from.
Making sure you don't touch any moving parts or you won't be hearing the ambulance coming! ;-/
#7 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 20 April 2014 - 12:27 PM
http://www.vx220.org...6-ticking-vxts/
#8 Nev
Posted 20 April 2014 - 02:17 PM
As someone has already said, it's most likely to be lifters or a lose spark plug. To test if it is the lifter, rev it quite hard for 4 seconds, then let it idle, if the ticking has gone briefly (due to higher oil pressure) then you can be fairly sure it is the lifter not zero-ing the lash.
#9 Acidpopstar
Acidpopstar
  • 3,555 posts
Posted 20 April 2014 - 03:53 PM
I have an NA that makes a very similar noise on start up but seems to go away after a getting the revs up and the engine is warm. Could it be a similar problem?
#10 Nev
Posted 20 April 2014 - 04:27 PM
Yea, lifters. Ignore it until the noise is constantly there as it is of little consequence in practice. Change your head if bugs you, or more expensively change the lifters (and maybe the cams if the lobe is worn).
#11 vocky
Posted 20 April 2014 - 04:40 PM
it could either be the exhaust manifold is cracked or your timing chain needs replacing.
#12 Acidpopstar
Acidpopstar
  • 3,555 posts
Posted 20 April 2014 - 06:12 PM
What's the easiest way of checking these things out in particular the manifold? Sorry I'm so incompetent.
#13 CHILL Gone DUTCH
Posted 20 April 2014 - 06:30 PM
If your on standard manifold take the heat shield off and check for cracks Also add some soapy water on manifold to see if there is any minor cracks I suspected cracks and left it, later the manifold nearly split into two
#14 Acidpopstar
Acidpopstar
  • 3,555 posts
Posted 20 April 2014 - 07:34 PM
Blimey. Cheers for the heads up Chill. Off to Spa at the weekend, should I be worried??
#15 CHILL Gone DUTCH
Posted 20 April 2014 - 07:36 PM
Only if it's cracked
#16 ciderbooze
ciderbooze
  • 1,216 posts
Posted 20 April 2014 - 07:38 PM
If it does turn out to be the manifold ( and it's std , which I think yours is) I have a spare you can have. Edit just to add , it didn't sound like a cracked manifold last time I heard it but we weren't diagnosing that at the time. I do remember the ticking and thinking that it sounded different to mine.
Edited by ciderbooze, 20 April 2014 - 07:41 PM.
#17 Acidpopstar
Acidpopstar
  • 3,555 posts
Posted 20 April 2014 - 07:41 PM
Yeah it's standard. That would be bloody awesome mate if it comes to it!
#18 davidp
davidp
  • 56 posts
  • Interests:cars,cycling,horse riding
Posted 17 April 2018 - 12:32 PM
What was the cause of the ticking noise in the end ? Mine seems to have started making the same noise
#19 siztenboots
  • 26,610 posts
Posted 17 April 2018 - 12:49 PM
the next autoplay video of stilfserjoch is more interesting
#20 siztenboots
  • 26,610 posts
Posted 17 April 2018 - 12:58 PM
the video is four years ago, unlikely to find out
noises can be tricky to isolate against normal loud pulses
