Why 16" Front Wheels Or 17X8" All Around?
Posted 29 April 2014 - 09:40 AM
Posted 29 April 2014 - 09:59 AM
I may be wrong but I think you're highly likely to get alot of rubbing on the front wheels if you go for 8" width.
I also wanted 17's all round, mainly for the looks but it has also kept us out of any ABS problems. In the end we went for 17x7.5 (et20) fronts and 17x8 (et35) rears with 205/17/40 and 235/17/45 tyres, great combo so far!
Posted 29 April 2014 - 10:18 AM
17 inch fronts are too tall really,
Assides that, 8 inch wide is way too much.. (as is 9 inch rears).
Realistically, 7j16 and 8j17 (or maybe 8.5j17) are ideal.
Same with tyres, 200 wide is more than enough for the front.
Posted 29 April 2014 - 10:44 AM
Make sure you look into the import tax on the MAK XLR wheels, unless you know a UK dealer.
They do make these in the correct size, ie 16 front and 17 rear
Edited by T VXT, 29 April 2014 - 10:45 AM.
Posted 29 April 2014 - 11:34 AM
OP's Location = Sweden
Posted 29 April 2014 - 12:43 PM
You can install 8x17 wheels at the front but you will need to modify the wheel well with extension
If you have similar wheel front and rear you will have a wrong offset somewhere (unless you use shims to reach the right offset).
But because you will use different tyres you won't be able to rotate them .
Posted 29 April 2014 - 08:53 PM
Posted 04 May 2014 - 12:37 AM
Posted 04 May 2014 - 08:24 AM
