Shift Light Installation / Tacho Wire
8 replies to this topic
#1 Ormes
Ormes
  • 4,612 posts
Posted 02 May 2014 - 11:10 AM
Hey .org
Bought one of those Shift-i shift lights as I want to pretend I am an F1 driver.
It needs live, earth and tacho wires to tap into.
For live, I intend to tap into the switched live of the stereo.
For earth, I will run to some bodywork.
For tacho, I will tap into the loom for the instruments... I have never read a wiring diagram in my life so can somebody validate please? :) It seems to be telling me that H1 is the connector, and H1.24 is the tacho connection, which is WHBK (White/Black) no matter whether it connects to a Z20let or z22se.
http://www.speedster...m/Instument.pdf
thumbsup
Edited by Ormes, 02 May 2014 - 11:15 AM.
#2 techieboy
Posted 02 May 2014 - 11:17 AM
Yep, tap into the white wire with the black stripe for the tacho feed.
#3 Silent Steve
Silent Steve
    Tit
  • 2,000 posts
Posted 02 May 2014 - 11:24 AM
Mmmmm Tacos.
#4 slindborg
Posted 02 May 2014 - 11:25 AM
I dont suggest the clams as good earth points ;) :lol:
#5 Ormes
Ormes
  • 4,612 posts
Cheers techie thumbsup
#6 Ormes
Ormes
  • 4,612 posts
Posted 02 May 2014 - 11:27 AM
:lol:
I favour the base of the gear mech
#7 techieboy
Posted 02 May 2014 - 12:01 PM
I earthed mine to the dash structure and used the same earth point as the airbag ecu.
#8 Arno
Arno
  • 1,238 posts
Posted 02 May 2014 - 12:06 PM
If you're picking up the 12V from the radio, why not run the ground wire to there too?
Good ground on these cars is not easy if you just use bits of chassis as the anodized ali has the tendency to insulate (it's removed by the factory around the main ground points for that reason) and the bonded extrusions don't really have to have metal-to-metal contact to the side chassis beam that's used as the main ground conductor.
Using existing ground wires or linking into the actual ground points on the chassis is usually the only way to get a consistent and durably good ground connection.
Of course this should not be a huge issue on something like a shiftlight but on stuff like dash gauges that rely for their function on proper grounding to get the correct reading it's vital. (not to mention any ICE install with an amplifier..)
#9 Ormes
Ormes
  • 4,612 posts
Posted 02 May 2014 - 02:55 PM
Thanks for the input arno thumbsup
