Car Just Died
14 replies to this topic
#1 simonlpearce
simonlpearce
  • 933 posts
Posted 05 May 2014 - 06:59 PM
Popped to see the olds pick something up. Car starts and drives perfectly. 20 mins later I come out to go home and when I go to start it, put the key in, turn to full, dash lights up as usual but car doesn't start then dash goes blank. No lights nothing. Now when I put the key in and turn there is absolutely nothing going on, dash doesn't light up or anything. Checked the battery and noticed the positive terminal was VERY close to the chassis. Have moved it away but it's still completely dead. Is it possible the battery has fried or has blown a fuse somewhere? I have been using it all weekend without any problems so the battery should be plenty charged. What's next to check?
#2 ant1
ant1
  • 298 posts
Posted 05 May 2014 - 07:03 PM
Spray both positive and negative terminals with wd40 and also the other end of the negative lead. Possibly a bad connection somewhere. Then check fuses.
#3 simonlpearce
simonlpearce
  • 933 posts
Posted 05 May 2014 - 07:07 PM
It certainly sounds like it could be a bad connection.. Where does the other end of the negative terminal connect?
#4 slindborg
Posted 05 May 2014 - 07:10 PM
Does it light up the cluster etc every time you try, but then won't crank? Either it's shorted to the tub (but your see scorch marks ) or you have been very unlucky and have a dead cell... It happens.
#5 simonlpearce
simonlpearce
  • 933 posts
Posted 05 May 2014 - 07:39 PM
Nope the dash doesn't light up at all, no lights no nothing. Will try jump start it to see if that helps. If it has shorted to the tub what does that mean, blown fuses or something?
#6 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 05 May 2014 - 07:46 PM
Had a problem with mine moving a bit on right Hand turns Shorting onto tub brought my e m l on and cut out for a second or two Take it the terminals are tight ? What about lights hazard etc I would try a jump start
Edited by christhegasman, 05 May 2014 - 07:47 PM.
#7 simonlpearce
simonlpearce
  • 933 posts
Posted 05 May 2014 - 07:53 PM
Yeah terminals are all tight. The positive is a little rusty looking though so might give that a clean and a good dose of WD and see if that helps. Will also try a jump and see if that will at least give dash lights and if so then looks like a battery replacement will be on order. Not checked the lights or hazards. Will have to look in the morning now though as getting dark.
Edited by simonlpearce, 05 May 2014 - 07:55 PM.
#8 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 05 May 2014 - 08:02 PM
Just if the hazards or sidelights work then it must be ignition power related If the lights or hazards are dead then its battery area I guess
#9 simonlpearce
simonlpearce
  • 933 posts
Posted 05 May 2014 - 08:05 PM
Ok thanks, I will take a look and report back. I have a feeling it will be something battery as the dash doesn't light up at all so I wouldn't know if the hazards were on.
#10 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 05 May 2014 - 08:20 PM
But the dash only lights up with the ignition on but the hazards will work with no ignition also the interior light. If these work look for ignition switch or relay issues if they don't work go for the battery first
#11 simonlpearce
simonlpearce
  • 933 posts
Posted 05 May 2014 - 08:33 PM
Ah ok cool, that makes sense so will take a look and see what's what.
#12 simonlpearce
simonlpearce
  • 933 posts
Posted 06 May 2014 - 11:06 AM
Problem solved!
Seems a slightly rusty positive terminal was at fault. Cleaned it up and dosed it in WD40 and she fired right up. Though i did find out that the alarm seems to have a battery of its own, which only gets louder when you attach the battery, which isn't so fun when your head is right next to the siren!
#13 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 06 May 2014 - 01:45 PM
Glad you are sorted I have a piece of rubber floor mat stuck to the tub between the battery and any bare metal to insulate the terminals from shorting just in case the battery moves again Just cut decent sized strips and secured with blobs of silicone sealant 😃
Edited by christhegasman, 06 May 2014 - 01:46 PM.
#14 simonlpearce
simonlpearce
  • 933 posts
Posted 06 May 2014 - 03:52 PM
Cheers Chris, thats not a bad idea! Will see what i have knocking around to stop that happening.
#15 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 06 May 2014 - 05:12 PM
No probs mate good is was only a basic cheap fix My rubber stuff is just a very cheap car Matt about 400 x300 cut into strips about 10 wide As I discovered like you that the do called battery clamp / washer bottle bracket is a good bracket but a crap battery clamp Maybe the newer generation of batteries are smaller ? But I wouldn't have fancied working a bigger battery in or out the car 😩
Edited by christhegasman, 06 May 2014 - 05:15 PM.
