Steering Rack Refurb Guide
Posted 07 May 2014 - 07:23 PM
Posted 07 May 2014 - 07:32 PM
Posted 07 May 2014 - 07:45 PM
It's not that difficult really, just a case of drilling out a lock nut, undoing the nut and replacing the cup under it. Worth getting the brass cups from Seriously Lotus as they wear a bit better (and don't crack!)
Posted 07 May 2014 - 10:13 PM
Posted 09 May 2014 - 08:50 AM
I did take it out and put it back only, that was OK (2 evenings with some music in the garage...) However I took it to a PRO for refurbishment (still it is about steering the car...)
Posted 11 May 2015 - 10:10 AM
Is titan still selling refurb parts?
I got this answer from elise shop: [font="arial, sans-serif;font-size:12.8000001907349px;"]My experience is the refurbs don't work as the rack bushes wear out as well and they can't be replaced.[/font]
Any thoughts?
Posted 11 May 2015 - 11:22 AM
I refurbed mine with brass bushes and also re-greased the rack and pinion at the same time, was an easy enough job just make sure the lock nuts finish in the same place or you will be adding / reducing toe. Also use some grinding paste to 'wear in' the new bushes.
If you are going to regrease the R&P you will need a massive spanner, I have the right one if you want to borrow it and I also have some spare grinding paste.
Posted 11 May 2015 - 12:42 PM
Where did you buy the brass bushes? And what grease did you use?
Posted 13 May 2015 - 04:44 AM
Posted 13 May 2015 - 08:30 AM
there is the small problem of the minimum order value with Titan, it might make sense to have a group buy of all the bits and make up kits to send out.
Posted 13 May 2015 - 08:39 AM
Damn it, I'm in....
Posted 13 May 2015 - 09:40 AM
Damn it, I'm in....
with option of the rack raiser plates for NA
Posted 14 May 2015 - 07:12 PM
Posted 14 May 2015 - 10:34 PM
Sorry, i giggled a little when I started to read that^^
Posted 17 May 2015 - 07:26 AM
Anywhere else to gett brass/bronze/poly bushes/cup for steering racks?Can't seem to get in touch with either Titan or Seriouslylotus. Anybody else selling these parts?
Posted 25 May 2015 - 06:36 PM
Can you please advice me how to take out the pinion part? I have removed the circlip, but the rest seems stuck in there... The guide says: "[color=rgb(0,0,0);font-family:sans-serif;font-size:12.8000001907349px;] use your vice and suitable sockets to press it out of the rack body.[/color]", but I don't understand how.
Posted 26 May 2015 - 03:44 PM
I didn't take the pinion out just opened it up so I could see the R&P interface and packed it with grease while rolling it left and right to get in into all the teeth. The only reason to press the pinion out is if you plan to replace it.
