Sub 800Kg Possible?
40 replies to this topic
#1 scottmasterton
scottmasterton
  • 8 posts
Posted 25 May 2014 - 11:57 PM
Hi Everyone
As it says in the title I'm wondering if its possible to get an N/A under 800kg and what parts/modifications it would take?
Also does anyone know the weight of the Z22SE and Box?
Thanks Scott
#2 Steffe
Steffe
  • 231 posts
Posted 26 May 2014 - 04:48 AM
Hello! Mine is reduced 820kg now and theres more that can be done. 1) wheels, originals are very heavy, go for some light weight variant, I have 15" front and 16" at back. 2) aftermarket exhaust system, will reduce weight 3) race battery eg odyssey 680 4) light weight flywheel 5) balance shaft removal 6) light weight aluminium fuel tank 7) stereo delete 8) fog light delete 9) headrest delete 10) egr delete, light weight alternator and other small fixes This would take you below 800kg
#3 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 26 May 2014 - 05:31 AM
Couple of links.... http://www.vx220.org...ight-reduction/ http://www.vx220.org...ight-reduction/ There's links within those as well....enjoy.
#4 Bargi
Bargi
  • 4,483 posts
Posted 26 May 2014 - 09:05 AM
If you require a roll cage I'd say you'd be hard up to drop it below 800kg
#5 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 26 May 2014 - 09:55 AM
7kg front clam saves 7-8 kg ;)
#6 scottmasterton
scottmasterton
  • 8 posts
Posted 26 May 2014 - 05:04 PM
Thanks everyone
Plan so far is to track the car initial weight is around 870kg and the parts listed below and others will be added/removed over time
VX220 Parts Endurance alloy tank -5.5kg
Heater Unit Removal -3.5kg
Speakers + Stock Airbox Removal -3.5kg
Tank Cover tray Removal -2kg
Carpets removal -2kg
metal/plastic headrest removal -2.2kg
engine/cockpit insulator -1.1kg
original seats replaced with reverie -15kg
Lightweight Front Clam -7kg
Insulation Behind Seats removal -3.5kg
Race Battery -6kg
Stock wheels replaced by Team Dynamics 15x8 pro race 1.2  -16.5kg
Single skin Hardtop -8kg
Carbon bootlid -6kg
T45 wishbones -8kg
Potential weight reduction total= 89.8kg
Potential Car weight= 780.2kg
Can you think of any other potential weight reductions?
#7 CHILL Gone DUTCH
Posted 26 May 2014 - 05:10 PM
Windows for plastic
#8 fiveoclock
fiveoclock
  • 9,453 posts
Posted 26 May 2014 - 05:21 PM
VX220 Parts Endurance alloy tank -5.5kg Done
Heater Unit Removal -3.5kg Done
Speakers + Stock Airbox Removal -3.5kg Done
Tank Cover tray Removal -2kg Done
Carpets removal -2kg Done
metal/plastic headrest removal -2.2kg Done
engine/cockpit insulator -1.1kg Done
original seats replaced with reverie -15kg Done
Lightweight Front Clam -7kg Done
Insulation Behind Seats removal -3.5kg Done
Race Battery -6kg Not done as wanted to keep weight over the front wheels
Stock wheels replaced by Team Dynamics 15x8 pro race 1.2  -16.5kg Done
Single skin Hardtop -8kg Done
Carbon bootlid -6kg Sprint lid fitted
T45 wishbones - Not done
With most of what you intend and a balancer delete, doors cut out, door beams cut out, single seat, no headlights, no interior apart from dashtop, rear clam floor cut out and with the addition of a cage and fire extinguisher system our car is at 850kg no driver, no fuel. Dont ask me how much the cage weighs
#9 scottmasterton
scottmasterton
  • 8 posts
Posted 26 May 2014 - 05:25 PM
Windows for plastic
Any idea how much of a weight reduction polycarbonates would be? as thats something Ive been thinking of as well
#10 fiveoclock
fiveoclock
  • 9,453 posts
Posted 26 May 2014 - 05:30 PM
Windows for plastic
We've got Lexan side windows and rear windows but dont know the weight difference. I would estimate around 4 - 5kg. Just checked and Safety Devices say the cage is 38kg
#11 scottmasterton
scottmasterton
  • 8 posts
Posted 26 May 2014 - 05:31 PM
one other thing that I'm going to look at is making carbon doors as have a lot of experience in making composite parts, just depends whether the calculated weight difference is worth it and a cage will be going in at some point. Also a lightweight rear clam would be nice I think someone already makes them?
#12 fiveoclock
fiveoclock
  • 9,453 posts
Posted 26 May 2014 - 05:32 PM
So without the cage ours would be around 812kg. getting that last 12kg out would be hard. I guess I would start with unsprung weight and change the TD's for Oz. I wouldnt put a poly front screen in.
#13 scottmasterton
scottmasterton
  • 8 posts
Posted 26 May 2014 - 05:35 PM
The TD's aren't final might end up going with something different and would never go with a poly windscreen, is the cage you're using made from T45?
Edited by scottmasterton, 26 May 2014 - 05:37 PM.
#14 fiveoclock
fiveoclock
  • 9,453 posts
Lots of grief making CF doors when you can just cut the originals down and take out the int door handles and put a cable in to get the weight down. Also if you're going to race it and someone whacks your CF doors it'll spoil your week!!!
#15 fiveoclock
fiveoclock
  • 9,453 posts
Posted 26 May 2014 - 05:39 PM
No
#16 fezzasus
Posted 26 May 2014 - 05:44 PM
doors weigh nothing, now you've got the cage in the best thing to do is remove the aluminium bar inside the door.
#17 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 26 May 2014 - 05:51 PM
2kg worth of carpets? Were they wet?
#18 scottmasterton
scottmasterton
  • 8 posts
Posted 26 May 2014 - 06:12 PM
Thats a bit of an exaggeration to balance the overall weight loss total out
#19 scottmasterton
scottmasterton
  • 8 posts
Posted 26 May 2014 - 06:14 PM
yeah that was just one of many ideas I have to reduce weight further
#20 turbotoaster
turbotoaster
  • 311 posts
Posted 28 May 2014 - 02:38 PM
its amazing how heavy the vx220 is compared to the s1 elise when they share a very similar ali tub, the NA engine is ali so its not like your carrying around a boat anchor in the back.
When you can get a s1 with a cage down to 630kg it just shows the difference(simonp, supercharged s1 with a cage is 640kg so lose about 10kg if you went to NA) you can save weight on the rear brakes
850kg vs 630kg, both with a cage, be interesting to see how they compare on track.
