Prestwold Hall is located near Loughborough and is new to the track day scene, having been used as a corporate event site in the past. The track has been recently resurfaced and now features a 1.7 mile circuit of tarmac, 10 metres wide. Whilst the layout looks very straightforward, it is an exciting circuit to drive with some high speed corners and a couple of technical complexes. The site is well served with a cafeteria and briefing room. In many ways, it appears to be the best of both worlds. The proper smooth surface of a track with the large run off areas normally associated with airfields. The surface is superb and very smooth.
Three VX220s attended the very wet day hosted by Bookatrack. They were myself, Mani and Richard. Mani was brave enough to allow his brother to drive as well! Other cars included the track day regulars such as Mk I and Mk II Elises, an Imprezza, a Caterham with no weather gear, a Ferrari Mondial, two Boxsters, two BMW M5s and a brace of Exiges. Instruction was provided to those that wanted it by Lotus Elise racer, Simon Scuffham.
Although the circuit is very smooth and free from debris, the approach road was terrible. Filled with potholes and gravel everywhere. Those that had tiptoed their way in were greeted with a clear, largely gravel free paddock and the friendly Bookatrack team. Although Bookatrack sell the venue with 30 places, only 17 turned up - presumably due to the weather. Therefore, Bookatrack ran the event as an open pit lane.
First up was the noise test. Prestwold is very strict on noise and has a 98 dB static limit and 87.5 dB drive-by limit. Each car was noise tested before being allowed out on track and Mani's with the Vauxhall sports exhaust was only just inside the limit. The Bookatrack team also monitored cars throughout the day to ensure the drive-by limit wasn't exceeded.
Since this is a new venue for track dayers, everybody went out for the sighting laps. This were led by Scuffham, showing that a Jeep can be rapid around a circuit in the wet! The circuit runs in a clockwise direction and following the main straight leads into a sweeping right hander. I was initially taking this in third, but tuition with Scuffham showed that, even in the wet, this was a fourth gear corner. Then up the hill to Elephant, which is a third gear right hander with a very late apex and difficult to master. Then continue up the hill round the sweeping left hander and onto the hangar straight. The right hander at the end of the straight is a quick corner, again in fourth, but a little unnerving as a mistake could see you in the trees. Then it's hard on the brakes for the tight right hander, before dropping into third for the complex. This is difficult to master as you have to go very deep on the entrance to avoid scrubbing speed on the second and third turns. The exit from the complex is a fantastic sweeping right hander where the power can be fed in for a launch down the main straight.
The morning was very wet with standing water over large areas of the track, particularly on the entrance to the complex. I have to say that the VX behaved impeccably, feeling very well balanced and planted. When grip was limited, the car tended to understeer, although oversteer could be provoked by prodding the throttle. As the track dried after lunch it got faster. The highlight for me was my last run of the day, where it was raining at the top end of the circuit and dry at the bottom.
As always with Bookatrack events, the day was very well co-ordinated and safe. The usual rules of overtaking on the straights and by consent only worked well and everybody behaved well.
Pictures are available here
Prestwold Hall - 2 May 2003
Started by
paulb
, May 03 2003 04:31 PM
4 replies to this topic
Posted 03 May 2003 - 04:31 PM
Posted 04 May 2003 - 06:11 AM
Sounds like a good circuit with better facilities than most airfield tracks. I fancied doing this one myself but had already booked for Hullavington on the same day.
If anyone here plans to book a day at Prestwold for later in the year let me know and I'll come up join in the fun.
Posted 06 May 2003 - 03:27 PM
It was my first trackday and I really enjoyed it. As far as the track was concerned, a good circuit with plenty of run offs-ideally suited for novices such as myself.
As Paul said, noise was monitored at standing and drive by. Just managed to stay legal with my vauxhall exhaust!
Paul- I'll send you some piccies over the weekend-some great shots!
Mani
Posted 06 May 2003 - 03:56 PM
Nice report Paul. I've managed to avoid wet track days so far, but an airfield day looks an ideal place to get to know the limits
Out of interest, did you note the noise level for a VX with standard exhaust? Was it much lower than Mani's? I've been at a couple of events recently, and the VXes with sports exhausts did not sound much louder than standard. Lots of pops and a nice burbling sound when coasting into the paddock area though
Posted 06 May 2003 - 05:43 PM
A lot lower. Mine was about 89 and Mani's was about 97...
Its put me off getting one. They do sounds superb though.
