Wheel Options
18 replies to this topic
#1 P11 COV
P11 COV
  • 7,686 posts
Posted 28 August 2004 - 01:30 PM
Given the discussion on the weight of the VXR wheels (which i was planning on getting) - what are the alternatives if I want to have 16in fronts and not change to Lotus hubs? Before anyone says - i know it may be around somewhere but I haven't got the energy to search!!
#2 VIX
VIX
  • 9,497 posts
Posted 28 August 2004 - 02:11 PM
Don't know the answer as I can never remember the sizes required - but ATS DTM wheels [HERE] look good. They feature on this chav'd VX Posted Image
#3 skogshuggarn
skogshuggarn
  • 1,088 posts
  • Interests:weightlifting and spending money on my car
Posted 28 August 2004 - 04:06 PM
Look @ http://forum.opel-sp...?showtopic=3319
Realy nice wheels thumbsup :D
ATS DTC 6.6kg front and 8.8kg rear thumbsup thumbsup thumbsup
#4 TLS
TLS
  • 8 posts
Posted 28 August 2004 - 05:30 PM
Looks like Saab wheels fit ... :o
http://www.myspeedst...topic.php?t=803
Guess they're not on the light side tho'
#5 Browncanoe
Browncanoe
  • 843 posts
  • Interests:Football, Computers usual stuff really.
Posted 28 August 2004 - 05:37 PM
Hey they look quite good :)
Browncanoe
#6 ECM
ECM
  • 888 posts
Posted 28 August 2004 - 06:45 PM
Wheels don't look too bad.
Bletch this link has an avatar on it just made for you ;)
#7 barrybethel
barrybethel
  • 1,112 posts
Posted 28 August 2004 - 07:31 PM
AFIK there aren't any other 16" front wheels that don't require lotus hubs to fit. OZ made superleggeras which would fit using special bolts (I have these) but Foxy has been told you can't get them anymore. You could get a bespoke set made but for 4 wheels it would cost £1200 or so
#8 ianrm
ianrm
  • 11,097 posts
Posted 28 August 2004 - 07:58 PM
http://www.myspeedst...topic.php?t=803[/URL]
Ruined by the F f f ford word. There I said it.
Edited by ianrm, 28 August 2004 - 07:59 PM.
#9 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 29 August 2004 - 04:16 AM
Or the Speedlines, lotus hubs set up that I, gary, Jim, Raul and a couple of others have got. Saves 5kg's per corner thumbsup You can get em in the shop ;)
#10 SPLAM
SPLAM
  • 6,491 posts
Posted 29 August 2004 - 09:42 AM
Thorney He said he didn't want the Lotus hubs.
Darn newbies. :P
#11 P11 COV
P11 COV
  • 7,686 posts
Posted 29 August 2004 - 10:29 AM
Can't see the Lotus hub in the shop - how much and how easy to fit?
#12 WoodenDummy
WoodenDummy
  • 2,552 posts
Posted 29 August 2004 - 10:37 AM
It think I'd have gone for the hubs sooner but I think it can get expensive. Hubs, new wheels, then new tries etc...
#13 m7mini
m7mini
  • 357 posts
Posted 29 August 2004 - 05:52 PM
As do Vaux astra turbo and vectra alloys - the only problem is finding a design wide enough - you then need slightly narrower tyres on the front (depending what set-up you are after)
#14 Thorney
Thorney
  • 11,404 posts
Posted 30 August 2004 - 04:59 AM
Just sorting piccies of them for the shop.
Fitting is a pop.....they simply replace the Astra ones complete with ABS sensors.....DIY is fine. thumbsup
#15 VIX
VIX
  • 9,497 posts
Posted 30 August 2004 - 09:14 AM
Opel Speedster club have ATS DTC's [clicky] for sale.
Anyone (eg a German speaker!) know if they're a straight swap? (I have no idea about off-sets etc :unsure: )
chinky chinky
Edited by VIX, 30 August 2004 - 09:15 AM.
#16 VIX
VIX
  • 9,497 posts
Posted 30 August 2004 - 09:20 AM
Thought I'd share this Babel Fish translation re the ATS DTC's - deep breath: Finite is it there! That again ATS Speedster wheel! Clearly fewer weights, better optics and innovativere technology was the goal, so plumb bob US and OPEL opel-Tuner Moto Concept from Wiesbaden. The wheel manufactured in the low pressure casting procedure has a substantially higher rigidity opposite, the forged and rolled wheels used so far in the road sport. Thus the driver receives a better and more exact feedback from the roadway and the chassis and/or finds faster and more exact he an optimal Setup. The Untersteuern is complete away and the handling optimally! Here we carried whole work out with the ATS specialists. There are the rims only with us! Ecklusiv for MCR manufactured. The wheels have the dimension 7.5 x 17 tariff and at the rear axle 9 x 17 tariff. Tires can be installed in size 215/45/17 and 245/40/17. The sum of accurate feedback and optimized Setup causes that the driver can brake later and out-accelerate in former times from the curves and the ungefederten masses are reduced clearly. The cooling of the brakes is substantially improved by the open many spoke Design, also it offers aerodynamic advantages at high speeds. The air turbulence at the outside wheel side is many smaller than with the normal rim. The sentence is supplied as follows: 4 rims, 10 high-strength wheel bolts (fG 10,9) for the front axle (in the back the old persons remain) Rims fit directly to the car. ET extension firmly at the rim as Compount! (MCR only) type appraisals after § 19/3 (at each gas station or TUEV, GUES Dekra etc..) A rim weighs for each VA 9,400 gram and hectar of only 10,800 gram. :o :o :o Love the "in the back the old persons remain" :lol:
#17 speedyK
speedyK
  • 6,846 posts
  • Interests:Er... cars?
Posted 30 August 2004 - 09:50 AM
Lotus Specials have the lighter ones as already mentioned above and on this forum >HERE<
Bolt straight on
  • Attached File  DTC.jpg   48.18KB   0 downloads
Edited by speedyK, 30 August 2004 - 09:50 AM.
#18 VIX
VIX
  • 9,497 posts
Posted 30 August 2004 - 10:33 AM
Speedy, Thanks for the info. I've posted a dumb newbie type question on the other thread (oops :blink:) querying how the wheel sizes of 7.5 and 9 in inches compare with 5.5J and 7.5J. I note the rims in the picture are 4 stud not 5. Presumably 5 are available. chinky chinky
#19 speedyK
speedyK
  • 6,846 posts
Posted 30 August 2004 - 06:15 PM
Yep so it would seem :)
