I'm guessing it thermostat?
Looks like a clam off job to replace it?
Pic from top looking into engine bay at the rear drivers side.
Pic from the side with arch liner removed.
Edited by simonlpearce, 06 July 2014 - 03:53 PM.
Posted 06 July 2014 - 03:51 PM
Posted 06 July 2014 - 03:53 PM
Edited by The Batman, 06 July 2014 - 03:53 PM.
Posted 06 July 2014 - 04:22 PM
Posted 06 July 2014 - 05:53 PM
Posted 06 July 2014 - 05:57 PM
Posted 06 July 2014 - 06:02 PM
Posted 06 July 2014 - 06:48 PM
Posted 06 July 2014 - 06:52 PM
The upgraded upgraded tensioner has the lump on it.
Posted 06 July 2014 - 06:54 PM
Posted 06 July 2014 - 07:08 PM
Yep after reading a TIS guide it seems a complete pig of a job.
it certainly is a barstool of a job, you should try removing the pump from the engine bay with the clam in place
ps: you need to remove both chain kits to replace it on a vx220
Edited by vocky, 06 July 2014 - 07:08 PM.
Posted 06 July 2014 - 07:17 PM
Posted 06 July 2014 - 07:31 PM
Two stages; Kit with the larger oil jets had nicks in the side of the tensioner Later the z20let tension was used, that's the one with the nipple on it, difference there was spring loaded vs oil pressureI thought the upgraded tensioner had the nipple on it? To change water pump you have to take timing chain off
Posted 06 July 2014 - 07:42 PM
Posted 06 July 2014 - 07:53 PM
Posted 07 July 2014 - 07:58 AM
If you have the proper locking/fixation tool then you can replace the waterpump without touching the chains.
This tool is attached to the chain sprocket on the front of the water pump and fits through/in the opening that's in the chain cover and allows you to keep it in place and undo the bolts.
http://munstertoolco...xhall-opel.html
Once this is in place you can remove the pump itself from the back and replace it.
Still a big job as you need to loosen/remove the thermostat housing too to get the ali connecting pipe out, which is not a very 'accessible' job. Also the space between the chain cover and the chassis/subframe is quite cramped so you need short/stubby tools to get the bolts in/out.
Posted 07 July 2014 - 11:04 AM
Definitely sounds like a job for someone that has done it before then! Might ring around some local places to see what sort of price its going to cost.
Posted 07 July 2014 - 11:49 AM
My pump started leaking recently. Car's at BOT this week to have new pump fitted. Rather them than me.
Posted 07 July 2014 - 12:11 PM
Surely the best way is to do it the Lotus way... As described by our tour guide, the two piece clam set is to make working on the car easy, by quickly removing the two clam shells.
Then I suspect it would be to disconnect the subframe and swing it out to work on.
That is if you have the necessary hoist.
Posted 07 July 2014 - 12:19 PM
Even with the clam off getting the sprocket bolts back in is a git.
