http://www.ebay.co.u...=item3ce3b6dbea
looking to polybush the VX and found this set, has anyone tried it?
Posted 13 July 2014 - 03:53 PM
Posted 13 July 2014 - 06:08 PM
Posted 13 July 2014 - 06:33 PM
I prefer them to stock rubber ones.
Posted 13 July 2014 - 07:04 PM
Posted 13 July 2014 - 07:19 PM
i prefer cars with polybush suspension and dont find any negatives with them. I have polybushed most of my cars over time and just done my 5 series BMW diesel. I have only ever found positives with them. I have never noticed any harshness in the ride compared to stock and the VX isnt exactly comfortable in stock form. Mine has stock bushes and my mates exige has poly bushes and it is much tighter to drive which is exactly what i have come to expect from a polybushed car
what are people thoughts on any polybushes then?
Posted 13 July 2014 - 07:25 PM
Posted 13 July 2014 - 08:39 PM
can i ask why you want to change them?
Posted 14 July 2014 - 08:44 AM
Edited by PaulCP, 14 July 2014 - 08:46 AM.
Posted 14 July 2014 - 09:07 AM
Its a little bit like everyone gunning for braided hoses (in all marques) claiming they are better than rubber.... well techniaclly yes they are, but if you compare a 10+yr old rubber hose to a new braided hose then of course things will feel different. Compared a NEW rubber hose with a NEW braided hose and there will be sod all in it unless you are a racing driver.
Posted 14 July 2014 - 09:19 AM
I think the consensus from another thread was that they are susceptible to wear through dirt getting in between the centre tube and bush and wearing the bush through grinding. Essentially its slightly harsher and wears poorly. If you want good location of the wishbones get sphericals which wear like poly bushes. If you want longevity / low maintainance fit new OEM ones.
Typically this came out after I'd fitted poly bushes. ....and if you're interested there's fook all diference between these and OEM on my car.
Posted 14 July 2014 - 09:37 AM
Posted 14 July 2014 - 09:42 AM
Posted 14 July 2014 - 09:48 AM
Posted 14 July 2014 - 09:51 AM
Posted 14 July 2014 - 10:08 AM
Posted 14 July 2014 - 01:43 PM
need I say more?
Posted 14 July 2014 - 03:55 PM
Edited by PaulCP, 14 July 2014 - 04:01 PM.
Posted 14 July 2014 - 04:11 PM
I have Polybushes fitted ,they let you feel every bump in the road ,not the smoothest of drives with these fitted on crappie roads. Most people seem to say stick with the OEM bushes as they give the best ride and handling
Posted 14 July 2014 - 04:31 PM
IMHO the only 2 real choices are:
- OEM (alike) bushings -> Fit and forget, work well and last ages
- Spherical bearing (Nitron, Pilbeam, etc.) or Erlaton -> Need regular maintenance and replacement, but tighter control of suspension movement
Polyurethane basically combines the 'bad' points from both into one.. They need regular maintenance/cleaning to stop dirt grinding away on the subframe/mounts and inside the wishbone eyes, while still giving a lot of compliance/flex in the bushings.
Ran most types of bushings on my car in it's 12+ year lifespan by now and have settled on Nitron spherical bearings for mine, but otherwise I'd have gone back to the OEM (alike) rubber ones.
Bye, Arno,
Posted 14 July 2014 - 06:03 PM
thanks gents, interesting point about the wishbones. Elise parts say the same thing and use it as a reason to fit their Ertacetal bushes. http://www.elisepart...ishbone-bushes/
And yes, you are right that i am comparing (possibly) worn rubber bushes to failry new Poly's, but i didnt want to fit new OEM ones to find there isnt a lot of difference and always wonder if i should have gone for Poly. Although i will have to check the exige doesnt have the Ertacetal bushes and just called them poly bushes.
Anyone else tried the Ertacetal bushes other than LY Scott?
