Honda Ctr Engine
Posted 28 July 2014 - 11:42 PM
Posted 29 July 2014 - 06:44 AM
Posted 29 July 2014 - 07:13 AM
Posted 29 July 2014 - 07:39 AM
Posted 29 July 2014 - 09:29 AM
Posted 29 July 2014 - 09:41 AM
Posted 29 July 2014 - 11:18 PM
Posted 04 August 2014 - 04:04 PM
I thought the Type R Civic got praise for the gear change.
The linkage and connections would have a fair amount of impact on the gear change feel though.
Posted 05 August 2014 - 04:23 PM
Mmm would probably still be better than our std gear change though.
Talking of gears, if it were possible to get the same max speed in each gear even though there is another 1,500 rpm before the red line it would mean the ratios would be very low. Meaning the power would be multiplied more so than using std gear ratios, the effect that 200 hp would have more effect than it would in a higher gear car.
Paulie
Posted 05 August 2014 - 05:18 PM
Posted 05 August 2014 - 07:41 PM
Posted 07 August 2014 - 04:01 PM
I have yet to drive a car with a more accurate gearbox than the VX I had... And in the last 2years I have driven most 'normal' cars.
you had a puma didnt you? best gear change ive ever used in a FRP
Posted 07 August 2014 - 06:11 PM
I did and doubt there is much difference to the FRP. It was smooth and effective, but the vx gear change was mechanical and accurate.you had a puma didnt you? best gear change ive ever used in a FRPI have yet to drive a car with a more accurate gearbox than the VX I had... And in the last 2years I have driven most 'normal' cars.
