Well I picked the car up a week ago today, had a few good runs out in it and it's everything I expected plus a few annoying rattles and squeaks, the car is super clean, not a spot of corrosion on the suspension arms and underside etc so can only assume the car has been used in the dry, it also came with an alloy rad upgrade which is an added bonus!!!
I had the airbox off today to see if it had been messed with as the induction sound was louder than I expected, it has the pipes removed but thankfully no holes drilled in it, when removing the airbox I did notice the inlet hose/clip hadn't been mounted on the box correctly which resulted in the hose being half on/half off the box and crushed with the clip being over tightened. After putting this right it seems to drive a lot smoother through the revs so can only guess that the combination of the restricted inlet and the hot unfiltered air from the engine bay was sucking power from the car at low revs.... The inlet pipework was squeaky clean so no concerns regarding dirt being sucked in so can only assume this was from the last service a couple of hundred miles ago
I managed to sort one rattle out which was the boot release cable so I've zip tied that back and all is well.
It also sounds like the aux belt tensioner could be running dry so will drop the aux belt off tomorrow and see how it feels.
No record of the gearbox oil being changed either and I don't believe in this lifetime oil malarky so will be changing that when i get chance!
Hoping to get the car to Evotune in Durham over the next week or so for a power run to check everything is running right before I tuck it away for winter, I think it's running a standard map, no receipts in the history showing otherwise and the engine feels like it has a lot more to give. If it makes good power and has no signs of being mapped I'll be getting it mapped and will try to resist modifying it any further
Apart from that for a 10yr old car it's in pretty good nick.
Will upload some photo's when I suss it out, for some reason I can't embed the url's from photo bucket......
