Had abs light on, found split wire on NSR, chassis side of the connector, not wheel end. Soldered it back together and that but the light did not go out.
Hooked up the op-com and got this, tried clearing it but returns immediately....
So I have not fixed it properly but I am looking at the correct wheel. I am not sure how to test the wires to find where the problem is. On the wire that was broken I used the multimeter continuity test mode one prong on the pin on the connector the other I cut open the sheathing further up from the soldering and it seemed okay. Diagram:
Not sure how else to test the wire I do not know how electric works. Maybe the solding is bad and the electric can't get through properly?
