Had my suspension refurbed and they sent them back with loose springs so had to work out ride height. Put them on and pretty good but wanted to raise each end up a bit more.
To do this assumed raise the top collars up the correct amount, the spring then would expand to fill that and voila new ride height, but, did that on the front and it went up. Did that on the back and it went down?????
So to confirm, do you raise the collars to expand the springs to raise ride height?
Does this not also have the effect of softening the spring effect as well as its less compressed?
Martin S
Not done this before but still have no idea why the front would go up and the back down, and yes they were both turned the same wayanti clockwise which moved tye collars upwards on the damper units.
