Indicator Failure
indicator electronics wiring stalk
4 replies to this topic
#1 Bandris11
Bandris11
  • 67 posts
Posted 24 September 2014 - 07:27 PM
Guys,
Recently visited a hillclimb race where we had rain for 3 days. Car was out in the rain full time. After getting home I realized the indicator did not work. Hazart did, but no indicator. Since I have some electrical skills I decided to check the following:
- fuses
- relay
- indicator stalk (this is a tricky one, since you´ve got to disassemble the whole steering wheel / airbag / plastic cover combo)
- hazard switch
I went through all of them, cleaned them, measured everything with a multimeter, all was fine, but still... no indicators. After I decided to assembly the steering wheel as I was sure the steering stalk was OK suddenly the indicators came alive again. Somehow I could not laugh...
But, once the light switch block was apart I repaired the headlamp switch as well - this maybe the only positive effect of my 4hrs work
(I don´t even dare to think about my winter plans to locate 2 very disturbing noises coming from behind the seat / engine bay I wonder if I will remove the headlieght also ??? :) )
#2 Robski
Robski
  • 1,905 posts
Posted 24 September 2014 - 07:46 PM
It's probably the wrong time to say this as you've done all that work but it could have been a good time to replace the indicator stalk as some do tend to fail causing the main beam lights to flicker on and off intermittently.
However, I'm also a great believer of "if it ain't broke don't fix it!" so you've probably done the right thing!   :)
#3 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 25 September 2014 - 03:22 PM
The disturbing noises you mention could just be the engine mounts wearing away. Does it happen when you accelerate? Easy fix.
#4 astravxr
astravxr
    Straight roads are for fast cars, turns are for fast drivers
  • 1,748 posts
Posted 25 September 2014 - 05:35 PM
Hey mate had the exact same problem last week. New stalk was needed. Taking steering wheel etc off is very easy, took me 5 minutes. My indicators didnt work straight away, i had to drive down the road then they started to work again
#5 Bandris11
Bandris11
  • 67 posts
Posted 26 September 2014 - 06:54 AM
Can be... Will dig into it when bad weather comes. My wife will like it: Her husband spends every evening in the garage :)
Also tagged with one or more of these keywords: indicator, electronics, wiring, stalk
