how easy is cooling fan to replace ?
is it clam off , because I have no idea how to remove it
Posted 26 September 2014 - 09:39 PM
Posted 26 September 2014 - 10:18 PM
Posted 26 September 2014 - 10:19 PM
Yep, clam off job. After that it's a piece of p*ss
*edit: damn it, I lose....
Edited by Gedi, 26 September 2014 - 10:21 PM.
Posted 26 September 2014 - 10:22 PM
Posted 27 September 2014 - 06:21 AM
Yup front clam off If you are near Aylesbury I can show you
that's very kind of you to offer , but im in Worthing , west sussex .
Posted 27 September 2014 - 07:30 AM
can I ask the fan wiring plug , is this the 2 wire connector black + black/green that plugs to black + .blue
if I give black and blue wire 12 volts direct to see if I can start fan working , looking at it through the grill the motor housing for the fan looks stained with rust ( not a good sign ) but thought a bit of lube might help it like wd40
Posted 27 September 2014 - 07:56 AM
Hi
I am in upper beeding have moderate garage faciltys & can help if required or test out your current fan (pun not intended) are you still running a standard rad, as if clam is coming off you might consider any other jobs/work at the same time.
Fred
Posted 27 September 2014 - 08:26 AM
Hi
Fred
that's cool of you to offer , cooling fan cut in last night and ran for about 5 seconds and sounded really bad and just stopped running , no blown fuses
just phoned steeles of Worthing part is located in Germany £176 , they are not franchised for this car so cant order the part .
I have no space to have a car sitting around with no clam on
think I will advertise car as easy winter project
Posted 27 September 2014 - 09:14 AM
Edited by pete-r, 27 September 2014 - 09:15 AM.
Posted 27 September 2014 - 09:19 AM
Just change the fan only.. much cheaper Take a day if you've never done beforethat's cool of you to offer , cooling fan cut in last night and ran for about 5 seconds and sounded really bad and just stopped running , no blown fuses just phoned steeles of Worthing part is located in Germany £176 , they are not franchised for this car so cant order the part . I have no space to have a car sitting around with no clam on think I will advertise car as easy winter projectHi I am in upper beeding have moderate garage faciltys & can help if required or test out your current fan (pun not intended) are you still running a standard rad, as if clam is coming off you might consider any other jobs/work at the same time. Fred
Edited by mbes2, 27 September 2014 - 09:21 AM.
Posted 27 September 2014 - 09:23 PM
Offer still stands, try another vauxhall agent, frosts at shoreham might help, pattern parts, lotus (back on thr track guildford) etc or apeal to the good nature of the members on here for a replacement. at what temperature did it cut in, try & bridge out the sender also my fan sounds like a bag of nuts
Posted 28 September 2014 - 07:15 AM
temperature the fan cuts in is 106 degrees C .
were abouts is fan switch located ?
Posted 28 September 2014 - 07:27 AM
Posted 28 September 2014 - 11:03 AM
ECU (via a relay) triggers the fan based on it's coolant temperature sensor. No separate fan switch.
Posted 28 September 2014 - 02:39 PM
wow you are a star , I will try and get some quotes during the week for someone to fit .
thought this part would be main dealer only ( £176 ) +vat
they even do a fitting kit to enable it to go back together properly
has any one fitted this fan to there vx220 , just want to know it fits before I order
