Wishbone Painting....
46 replies to this topic
#1 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 12 October 2014 - 04:37 PM
Plan to do a suspension refurb over the winter. The wishbones and uprights are ok, but do have rust spots and some pitting. So what the recommendations for the way forward. Powder coating.. Looks good, but not sure how it would do in areas of pitting. Plus the uprights might be a bit difficult to do. Hammerite.... easiest option, but paint can chip if or on to thickly. Por15. Great stuff, but finish is not as good as powder coat. Easy to do all parts though. Plate or passivated... I see that you can buy home playing kits and wondered if this would be a reasonable option. At the end of the day, its all hidden and the focus is on protection rather than looks.... So, the debate is open....
#2 anz3001
anz3001
  • 1,617 posts
Posted 12 October 2014 - 04:55 PM
I left mine in deox for a few days and then had them powder coated
#3 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
  • Interests:Big baps.
Posted 12 October 2014 - 04:56 PM
I've thought about this also as mine is due a suspension refurb.
I intend to galvanise as it lasts a couple of hundred years and still works with stone chips. I do agree it doesn't look as nice as powder coating, but as you say - it's all hidden. You could always paint over them if that's a big issue.
Interested to hear other views.
#4 Kieran McC
Kieran McC
  • 3,416 posts
Posted 12 October 2014 - 05:04 PM
Powder coating seems to be the prefered method for the whishbones etc.
#5 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
Posted 12 October 2014 - 05:30 PM
Why is that though Kieran?
#6 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 12 October 2014 - 05:43 PM
Because it cost me 4 packs of hobnobs :D
#7 Kieran McC
Kieran McC
  • 3,416 posts
Posted 12 October 2014 - 06:04 PM
The metal is cleaned shot/ bead blasted, Powder coating is a good hard protective coating if applied properly. Most owners I now seemed to have used this method.
#8 VX220BOB
VX220BOB
  • 625 posts
Posted 12 October 2014 - 06:11 PM
My mate has just stripped his lotus and he is planning in using Por15 as he has used powder coat and hammerite on other cars and found Por15 the best.
#9 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
Posted 12 October 2014 - 06:17 PM
How is galvanising inferior though?
Think Zoobeef has hit the nail on the head.
#10 ukcat
ukcat
  • 390 posts
Posted 12 October 2014 - 06:41 PM
Just a bit of advice on galvanising - allthough it is very good at protecting from corrossion it is more suited to certain applications and im not sure it is the best process for these components firstly as the parts are imersed into molten zinc (approx 400 deg) you must be carrfull with sealed parts as there is risk of explosion not sure the wishbone tubes would be suitable ! also components must be engineered to allow the zinc to drain away as they are withdrawn from the bath and will usually have holes to allow for this these holes also prevent trapped air when the item is placed in the bath - basically many items that are galvanised have an element of design which takes this into account. another issue is the coating thickness which is relativaly thick (compared to electro plating) and would cause issues with areas like the bush eyes and ball joint eyes and also threaded holes on the uprights sll these areas would require attention afterwards to remove the zinc ! This problem is also found with powder coating however masking the key areas as well as rrmoving any surplus is much easier . Have u considered having them re electro plated as there are usually local companies that will do them pretty cheaply once plated u can also paint or powder coat on top if u want this has the benefit of protecting the areas which are masked off as you still have the plating as opposed to bare metal Hope this helps Cheers Tony
#11 Kieran McC
Kieran McC
  • 3,416 posts
Posted 12 October 2014 - 06:49 PM
How well would hot zinc spraying holdup ?
#12 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 12 October 2014 - 06:51 PM
just get them powder coated look good protect the wishbones and fairly cheap.
#13 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,863 posts
Posted 12 October 2014 - 06:56 PM
Thanks Tony.
#14 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 12 October 2014 - 07:11 PM
Eliseparts are using a now type of poweredcoat/ paint on there wishbones which is suppose to be better and stronger then powerdercoat. They did tell me what it was but ive forgotten. May be worth giving them a bell and find out what it is.
#15 ukcat
ukcat
  • 390 posts
Posted 12 October 2014 - 07:22 PM
Not really familiar with hot zinc spray Also just be aware tha allthough powder coat is relatively cheap and looks good it can chip and once chipped it will rust underneath the coating this can sometimes go unnoticed for some time - dont want to scare you as it would take a long long time for a wishbone to rust through but just pointing out that powder can trap and hide corrosion again a good reason for plating first . I have used zinc nickle electroplating it is relatively new process and offers over 5 times the protection of the original plating which is just yellow pasivated zinc Tony
#16 Anarchy
Anarchy
  • 2,237 posts
Posted 12 October 2014 - 07:27 PM
I am fortunate to have a paint facility at work, I ask them to do it in a 4 coat ISO 12944 C5M paint system normally used for off shore carbon steel, probably overkill but it has lasted 8 years or so and only cost few bags of fish and chips and lottery tickets.  Not easy for everyone but I know local paint shops can paint the same system but not sure what they would charge.
#17 Arno
Arno
  • 1,238 posts
Posted 13 October 2014 - 07:18 AM
Best procedure usually is:
- de-rusting (chemical or electrical)
- zinc plating (either hot-spray or electric/galvanisation)
- topcoat (POR, powdercoat, etc.)
That way you get the best result. The original rust will be gone, the zinc layer provides the cathotic protection and the topcoat gives the weathering protection.
If the topcoat is chipped then the zinc layer will stop the rust from spreading under the topcoat.
It's always a good idea to use some form of rust inhibitor base layer under any paint/powdercoat.
If you want to tart it up properly you could also have it shinly nickel-plated after the zinc layer (or tri-nickel plated) and then topcoat it with clear POR15.. Bling! B)
#18 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 13 October 2014 - 09:06 AM
http://qr.absoluteco...alReadyInfo.pdf
#19 robin
robin
  • 3,810 posts
Posted 14 October 2014 - 06:32 PM
powder coating is fine till it gets rust under it and goes all crappy,is a great system but is a paint to remove.
i 2 pack painted my suspension and still looks as new.
#20 Pidgeon
Pidgeon
  • 5,254 posts
Posted 15 October 2014 - 07:40 AM
Hammerite is bottom of the pile, well marketed but not that good for the job, chips and lifts easily.
Being a pilkey I used POR 15.  It's lifted where it's been disturbed (bolt holes etc) so still not ideal.
