Hi All,
I have a full 4pot conversion kit but I no longer require it.
In the kit is the following:
2x AP 4 pot callipers (CP7624's)
2x 308mm drilled and grooved 1-piece discs (Not AP)
EPTuning braided brake hoses
Full set of AP-branded Ferodo DS2500 pads (for the 4 pots - just to be clear this kit does not include rear pads)
2x AP calliper mounting brackets to suit VX220 with 308mm discs
Full set of correct bolts for mounting brackets to hub, and calliper to bracket
Full set of pins and anti-rattle springs
1x bottle of Loctite 270 as supplied in the kit by AP
1x AP brake manual
1x AP sticker...
Everything is brand new unused - although I have personally trial fitted a calliper and disk to my vx220 to guarantee it will all fit. This is the same kind of kit that would have originally been supplied by Thorney.
Looking for £1100, first to PM secures (unless that is no longer the .org rules)
I'm sorry to all you guys outside the UK but I don't want to send these abroad unless no one from the UK is interested
(PS apparently calliper is the correct English spelling, rather than US caliper)
