Many thanks for your response, not actually driven the car at the moment awaiting delivery of 2 new track rod ends.
We have an elise in the family an early S1 and i have never experienced bump steer at all in this car, interestingly the elise manual shows the raiser plates fitted as standard and secured in position by pop rivets at the lower small hole so that secures and this aligns/locates the mounting bolts to true position during steering rack fitting. Agree the rack needs to be as high as possible you can get it.
Our vx appears to have had a raiserplates/pop rivets fitted but has corroded away (pop rivets) by the dreaded bi-metallic corrosion which is all over these cars, if you look on Lakeside Lotus site you will see front suspension towers rotted away on an elise. I cleaned our towers and yes there was a deposit forming but only surface fortunately.
Going to get the car tracked up etc, not a big fan of the Geo laser prefer the conventional laser setup, adjusting to 0.2mm or 0.008in is fine when the car is brand new/rebuilt suspension, but slight play in bushes/ softing effects; allowing flexing in motion and wheel bearings (slight play, but still MOT pass) will give a different result everytime, yes i have tried it and gone back 4 times and got different results and the suspension appears firm by inspection. The geo tech laser like any system is purely static checking, ideally you want dynamic/vehicle moving check and this would show up any suspension issues/set up changes required, obviously would cost to much.
Bumpsteer
To ensure each front wheel moves in equal amounts (steering rotation) to the other during all suspension movements the rack has to be parallel to the suspension points and also the tie rods need to be the same length also ie centre of ball joint to centre of inner tie rod, in other words parallel geometry. If this is not the case of one the 2 wheels will toe out/in more than the other in front end bump/dive conditions and hence pull the vehicle in that direction left or right as you drive over bumps. The geometry has to be equal other wise trouble. Basically the standard steering rack geometry appears to be roughly inline with the track rod ends, the eliseparts kit lowers the track rod end position (angled up to the rack/rack higher) and would give a toe out effect during going over a bump.
Sorry to go, on thinking aloud!! must go out and try the car, may be worrying about nothing!!
Tedski
