Hello would really appreciate some help
So VX220 ownership is now the second most stressful thing I think I have done !!!
Day 3 and already in the same situation as some of the membership would recognise, but maybe with a slight twist.
Pick up car Monday great start (have owned several other toys and VX220 so good). Came up the Motorway to my exit complete loss of power.
Pulled over onto hard shoulder still had engine run and was able to limp up the exit ramp no engine management lights on
Got car home read threads and have done the following
Took out what I thought was fuse 8 and reset the engine management unit. (but did not know which was fuse 8 so counted 8 from the left on both fuse rails and removed them both.
Replaced and started car and low and behold throttle response was back.
Shut down can and re-started no throttle again and hazard lights keep blinking. Pinged the key fob and eventually they went off. Took out fuses again and replaced and hazards came on car starts but they continue to flash no throttle response.
Took off the pedal connector and cleaned
Took of the ECU connectors and cleaned and
Took of the 2 connectors that are difficult to get hold of behind the overflow water bottle
Still no throttle response, came in here to write help request and to calm down for a moment.
Can anyone assist please, the hazards lights are on as soon as I turn the engine over and the throttle response is zero.
Many thanks
