Exhaust Manifold Wrapping
Posted 07 November 2014 - 12:20 AM
Posted 07 November 2014 - 12:32 AM
Posted 07 November 2014 - 08:18 AM
Another vote for nimbus here.
Posted 07 November 2014 - 08:22 AM
Just remember that if you wrap the manifold/exhaust the heat has to go somewhere else and can cause burn/heat issues further down the system
Posted 07 November 2014 - 08:55 AM
Have you asked Tullet?
Posted 07 November 2014 - 09:02 AM
do you have a cat exhaust , have you checked your lambda / manifold for leaks.
Posted 07 November 2014 - 09:03 AM
Stainless steel manifolds (So not OEM cast ones..) are heatwrapped to keep the heat "inside" wich results in a higher flowspeed in the manifold. Cast ones have more mass/heavier so they keep heat in much easier.
That's the technical theory. I never felt a real difference in spoolup heatwraped or not. Heatwrapping is a nice thing when you dont want to melt everything down or need to put your hand in a hot enginebay.
I would do it in a VX whit an aftermarket manifold.
Posted 07 November 2014 - 10:16 AM
I was also wondering whether my one remaining CAT would work better (less emisions) with more heat going through it?
Kindly, Paul
Edited by Paulus H, 07 November 2014 - 10:16 AM.
Posted 07 November 2014 - 10:24 AM
Another vote for a decent heat shield. Get rid of the crappy foamy stuff, which can, like my previous one, detatch itself and touch the exposed manifold, consequently going on fire and nearly melting the whole car on Courtenay's dyno..
With a sheet of nimbus installed (2 /3 holes in the rear clam for bolts, and leave a small air gap between the nimbus and the boot wall, use washers if necessary), it was no hotter than before, despite an exposed Tullet manifold..
You can also apply some of that adhesive, reflective insulation on the boot wall before the nimbus.
Edited by Rosssco, 07 November 2014 - 10:26 AM.
Posted 07 November 2014 - 11:29 AM
Kindly, Paul
Too much heat and you risk melting it.
Posted 10 November 2014 - 08:36 AM
Edited by Nev, 10 November 2014 - 08:59 AM.
Posted 10 November 2014 - 09:21 PM
Posted 11 November 2014 - 12:38 AM
Thanks Nev, do you have any advice as the best practices for wrapping? I have never considered this on any of my previous cars but the Tullet really heats up the engine bay and if there are no tangiable downsides I am inclinded to give it a go. Thanks for your advice, PaulI'd advocate exhaust wrap over Nimbus wherever possible, because: 1/ If you use exhaust wrap it contains the heat in the pipework, thus keeping the engine bay temps down. This is the key reason to use it IMO. 2/ It doesn't rattle. 3/ It doesn't bend/break over time. Critical hot things like manifolds can be double wrapped and it really makes a significant difference. The thing about using Nimbus is that you have already allowed the heat to escape, and all the Nimbus does is refelect that excaped heat somewhere else. ie it is a retro-active solution, where as exhaust wrap stops the problem at source and forces the heat out of the back of the exhaust (where it should go). I have been using exhaust wrap on my car for the last 5 years at least, I don't need to use any heat shielding at all around my turbo or exhaust manifold what so ever. I have completely eliminated the chimney above the exhaust manifold, the delicate brackets around the engine mount shields and gear cable shields, all without any heat problems. QED.
Posted 11 November 2014 - 11:12 AM
Damp it before using it as it makes it more flexible / easier to apply. Allow for a 50% overlap as you wrap which will result in a double layering. Use plenty of stainless tie wraps to hold it all on!
Posted 11 November 2014 - 12:15 PM
Dude that was exactly the kind of advise I was looking for thanks!
Paul
Posted 11 November 2014 - 12:18 PM
and if you go for the spray stuff that you apply after its wrapped, make sure you get some sort of PROPER spraying mask to wear as I did a manifold with it and was wearing a 2K compatible mask and I could still smell the solvents from the wrap spray.
Did make it last longer though.
Posted 11 November 2014 - 09:27 PM
Yes, exactly this. I have never used the spray after wrapping, but I can only think it would help prolong it's life too.Damp it before using it as it makes it more flexible / easier to apply. Allow for a 50% overlap as you wrap which will result in a double layering. Use plenty of stainless tie wraps to hold it all on!
