Vx220 Turbo Gaining Revs Between Gearchange
6 replies to this topic
#1 paggycam
paggycam
  • 17 posts
Posted 15 November 2014 - 12:11 PM
my vxt has started holding revs between gear changes, if you rev it  to say 4000rpm it will gain 1000rpm before the revs dropping down, any ideas ?
#2 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 15 November 2014 - 12:17 PM
Sounds like the symptoms of a slipping clutch.
#3 rob999
rob999
    Cat in a Hat
  • 12,795 posts
I believed TADTS to a point. How olds the clutch?
Edited by rob999, 15 November 2014 - 12:18 PM.
#4 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 15 November 2014 - 12:44 PM
It's the clutch switch (on the clutch pedal/in front of it) not being fully depressed because the bracket holding it is made of cheese and over times gets moved further and further away (mm's) from the clutch pedal in its rest position. Could also be due to a tired clutch return spring not fully returning the pedal and so again not depressing the switch.. Needs a little adjusting.
Edited by VXT Tim, 15 November 2014 - 12:50 PM.
#5 paggycam
paggycam
  • 17 posts
Posted 15 November 2014 - 01:28 PM
thanx for your help everyone, was reading about clutch pedal switch, climbed under the dash and the bracket had bent, so the switch wasnt touching the pedal. gave it a bit of a move. seems ok now  :happy:
#6 Ormes
Ormes
  • 4,612 posts
Posted 15 November 2014 - 02:34 PM
thumbsup
#7 jonathansouth
jonathansouth
  • 231 posts
Posted 15 November 2014 - 05:56 PM
Must be the time of year... mine has been doing the same, I'll be checking out the clutch switch tomorrow as that seems to be the cure to this common fault.
