Headlights Water Seals?
19 replies to this topic
#1 gav89
gav89
  • 215 posts
Posted 28 November 2014 - 12:02 AM
I know this subject has been covered to death but there is a variety of different methods out there and would like some input. My lights are pissing the sh*t out of me at the min. I sealed them a few years ago and they are misting up with just the hint of moisture in the air.
So heres what I plan.......
Remove and clean Lenses and put anti fog liquid on the inside before reseal
Reseal lenses with Butyl tape, then add abit of tiger seal for good measure.
Put neoprene  foam tape around light where it makes contact with the clam
Rears:
Same as above but buy new thick neoprene foam to replace existing foam gasket
Any other suggestions, so I can once n for all have a car that doesnt need the hairdryer taking to it on a weekly basis.
Thanks!
#2 fezzasus
Posted 28 November 2014 - 07:17 AM
Don't mix different types of bonding agents. Either butyl tape or polyurethane. After running the former for 8 months I would recommend the later as butyl tape never sets and causes the lenses to sag.
#3 gav89
gav89
  • 215 posts
Posted 28 November 2014 - 08:27 AM
Did vauxhall not use butyl tape on the OEM lense tho? I should have explained more, I'm not gonna use tiger seal as the adhesive.I was planning on using the tape to first bond the lense to the cluster, then use tiger seal around the edges to form a secondary water seal
#4 fezzasus
Posted 28 November 2014 - 09:05 AM
I still wouldn't do that.
Two reasons:
1. the different adhesives will expand and contract at different rates, this could mean one adhesive breaking the seal the other one has created by expanding more, forcing the gap between the lens and rear section of the light.
2. chemical compatibility, it's likely the polyurethane will make the butyl tape brittle.
#5 oakmere
oakmere
  • 2,143 posts
Posted 28 November 2014 - 10:49 AM
How about using silicone as the sealer or will the problem still be the same? I have used tiger seal on the rear lenses but it seems to form micro cracks in the lense. I am not sure if this is the lense or the tiger seal braking away from the lense?
#6 fezzasus
Posted 30 November 2014 - 07:33 AM
Not enough grab. Polyurethane is the way to go, it's a case of trying different types. Sikaflex might be better
#7 smiley
Posted 30 November 2014 - 07:42 AM
I use tape for bonding and silicone on the edges as water seal. no complaints so far, but I try to avoid bad weather with it so may not be a fair example for heavy use.
#8 gav89
gav89
  • 215 posts
Posted 30 November 2014 - 10:41 AM
Yeah I reckon tape bonding (cos thats what Vauxhall did) then put a bead of silicone on the outside edge for good measure
#9 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 30 November 2014 - 10:42 AM
This stuff is what I used to bond my headlamps together and it's still working perfect http://www.elisepart...cover-adhesive/
#10 oakmere
oakmere
  • 2,143 posts
Posted 30 November 2014 - 09:30 PM
I ment the butil tape + silicone, not silicone alone. Tiger seal might not allow the lense to expand and contract enough causing the cracking on the bonded surface.
#11 Exmantaa
Posted 30 November 2014 - 10:52 PM
Chemicals in certain adhesives will cause the hairline tension cracks in the plastic, so best use OEM-like stuff on the lenses... (At work we had once ethanol cleaning that caused stress cracks in pespex.)
#12 fezzasus
Posted 30 November 2014 - 11:00 PM
Butyl tape
Pros:
It's re-settable, you can heat it up to adjust to fill any gaps or move the lens about.
It doesn't chemically bond, so won't damage the lenses
Cons:
Not all butyl tape is the same, you need a high melting point one (such as the one sold by EP in the link above), lower melting point type run the risk of lenses sagging in hot weather
Polyurethane
Pros
Strong adhesive bond,
Can be applied more thinly than butyl tape
Cons
Not all polyurethane is the same, some will be more aggressive to the polycarbonate lenses or black paint, causing cracking or paint flaking. Tiger seal appears to, Sikaflex does not (so far)
Cannot re-set
#13 Gopherit
Gopherit
  • 77 posts
Posted 27 March 2015 - 01:12 PM
Is this the tape to use?
http://www.3mdirect....mm-x-10m-1.html
It's available in a variety of widths  so if it is the correct stuff, what width do I need? Supposedly ok to an intermittent high 150deg C but only down to -20deg C.
#14 fezzasus
Posted 27 March 2015 - 01:24 PM
Probably the same stuff, but it's cheaper.
Edited by fezzasus, 27 March 2015 - 01:24 PM.
#15 r2mlb
r2mlb
  • 772 posts
Posted 27 March 2015 - 01:36 PM
http://www.eliseparts.com/products/show/7/327/headlight-cover-adhesive/   Probably the same stuff, but it's cheaper.
So I've used the EP butyl tape and found it spot on. I have also ordered tiger seal to do exactly as others have thought, fill the gap to make double sure its air tight. Am I right therefore in assuming your recommendation is just to leave mine as they are and the EP tape will do the job on its own?
#16 fezzasus
Posted 28 March 2015 - 06:53 AM
Yes, use one or the other, not both.
#17 Chris p
Chris p
  • 71 posts
Posted 05 May 2015 - 05:18 PM
Just wondering how much of the elise parts tape I need to buy, will one roll do all the lights? front and back.
#18 r2mlb
r2mlb
  • 772 posts
Posted 05 May 2015 - 09:00 PM
I was told 1 roll would be enough for the headlights but frustratingly it wasn't and needed a fraction more... I'd advise 2 rolls to be on the safe side, 3 if you're going to do the rears too.
#19 FLD
Posted 06 May 2015 - 07:24 AM
I used PU adhesive (tigerseal) on mine.  I used PU primer (winbond) on the bonding surfaces first.  I have no cracks in the lenses at all.  Cracks could also be stress cracks if you've clamped on the lens while it cures and then released it.  The lenses I've cut off lamps before all seem to have been stuck on with PU adhesive and then double sealed round with more PU.  I've done 3 sets of lamps but they were all the early 'thompsons plastics' ones.
#20 slindborg
Posted 06 May 2015 - 12:45 PM
Make sure the breathers on the back of the light units are clean and functioning...
All this sealing lenses on and sh*t wont mean a thing if the back of the lights are letting moisture in but not out again...
