Hi,
Probably a stupid question but I don't want to damage anything. My ABS light is on and the speedo behaving erratically. I suspect its the connection to the hub but thought I'd check the fuses first - in particular 22. Browsing through the site I see that it might also be useful to remove Fuse 8 for a few minutes to see if a reset may help but wasn't sure whether I should do this with just the ignition switched on or the engine actually running, or whether it doesn't make any difference.
Thanks
