Supercharger Stage 3
12 replies to this topic
#1 Krusty
Krusty
  • 527 posts
Posted 03 January 2015 - 03:29 PM
I have a stage 3 engine and going to put the supercharger off my stage 2 on it, I have 2.9 pulley to go on and doing the dual pass mod, is there anything else I need I assume I need a shorter belt, am I right in saying 1270? Putting a 255 fuel pump in, do you need to do anything to the fuel lines Thanks Then just the exhaust to sort, what a nightmare that is, needs to be quiet as thruxton is my nearest circuit, Also who can map the Dutch ecu, anybody near to Berkshire?
#2 CHILL Gone DUTCH
Posted 03 January 2015 - 03:34 PM
Has it got cams ?? If your willing to drive to cheshire I will do it for you The journey won't be wasted as you can do the fuel learn on the way I run a 1270 with a 3.1 pulley so it might be a little big bit might get away with it
#3 Krusty
Krusty
  • 527 posts
Posted 03 January 2015 - 03:51 PM
Engine is courtenays stage 3
#4 smiley
Posted 03 January 2015 - 04:10 PM
What does that mean in detail? (ie what has actually been done to the engine)
#5 Kieran McC
Kieran McC
  • 3,416 posts
Posted 03 January 2015 - 04:11 PM
I run a 2.9" pulley on mine you do get a louder wine from the induction with this size.Is it a moduler pulley set up or push on ?
Edited by kieranmcc, 03 January 2015 - 04:12 PM.
#6 techieboy
Posted 03 January 2015 - 04:14 PM
I run a 2.9" pulley on mine you do get an annoyingly loud banshee whine from the induction with this size (and probably a world of IAT issues).
#7 CHILL Gone DUTCH
Posted 03 January 2015 - 04:57 PM
2.5 " exhaust is good for a little over 300hp but only just
#8 CHILL Gone DUTCH
Posted 03 January 2015 - 04:59 PM
Also I. Achieved 300 ish with 2.5 exhaust a 3.1 pulley
#9 Krusty
Krusty
  • 527 posts
Posted 03 January 2015 - 05:07 PM
Was that a full 2.5 system including manifold? What would happen if I kept the standard pre cat removed exhaust ? Would it really strangle the engine ? It was 247bhp at stage 2
#10 Kieran McC
Kieran McC
  • 3,416 posts
Posted 03 January 2015 - 05:14 PM
Full system 2.5" inc manifold Tullett , 2.9 pulley ,uprated fuel pump 300 bhp about max for this
Edited by kieranmcc, 03 January 2015 - 05:15 PM.
#11 CHILL Gone DUTCH
Posted 03 January 2015 - 08:43 PM
It maybe a bit restrictive but I'm sure you can get 270+ HP If you have standard manifold I'm sure you will crack that very quickly Do you know anything about engine internals as a stage three engine is very vague
#12 Kieran McC
Kieran McC
  • 3,416 posts
Posted 04 January 2015 - 09:00 AM
CS give a brief description of a stage 3 engine on their Web site.
#13 CHILL Gone DUTCH
Posted 04 January 2015 - 09:27 AM
Very brief Stage 3 conversion; further management enhancements, re-worked cylinder head, steel rods and cams, injector and pulley change. Gains to 290-300bhp with 250lb ft torque. With the option of a harrop supercharger and engine rebuild with stronger pistons gains up to 380bhp. - POA Please call to discuss your requirements.
