Battery Charging Idea - Good Or Bad?
23 replies to this topic
#1 Sol
Sol
  • 122 posts
  • Interests:Cycling, Football,Sailing, Golf.
    My Car.
Posted 19 January 2015 - 08:50 PM
Hi all, I know there are some clever guys on this forum and I wondered what you thought about putting a battery charger on a weekly timer for a couple of hours to keep a stored cars battery charged. I am newly retired & so do not use my car daily any more. It now sits in my garage and doesn't move for several weeks at a time, and the battery runs flat. Stupidly I connected a battery charger, and forgot I'd put it on, and have over-charged & ruined my battery. New battery ordered. I know the correct thing to do is to buy an intelligent trickle charger (Ctech) £60-£70. But as I don't have much money I wondered if I could put my battery charger on a timer (circa £10) so that it charges the battery for a couple of hours once every few weeks. I'd welcome your thoughts?
#2 Harry Hornet
Harry Hornet
  • 4,973 posts
Posted 19 January 2015 - 09:00 PM
...why not just start the car and leave running once a week if you dont want to take it  out...helps move stuff around as well......
..does the job for me and it stands outside.......
or wrap it up in blankets and keep it warm.........
HH
#3 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 19 January 2015 - 09:02 PM
Don't put the alarm on and it should last for about a month.
#4 Exmantaa
Posted 19 January 2015 - 09:18 PM
For long term storage in my cold garage I simply disconnect 1 battery clamp. Started (with some hesitation) even after several  weeks/months...
Edited by Exmantaa, 19 January 2015 - 09:18 PM.
#5 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 January 2015 - 09:19 PM
Trickle chargers are cheaper then £50. Lidi where selling one for £12 I think it was which is going to be safer and more reliable then a timer and battery charger.
#6 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 19 January 2015 - 09:21 PM
As I understand it a normal charger can still overcharge a battery Much better to get a trickle charger even a cetek can be had for around 30 quid http://pages.ebay.co...id=121265996287 or as above get a quick release clamp for your battery and disconnect it
Edited by christhegasman, 19 January 2015 - 09:23 PM.
#7 myles
myles
    Sausagefest
  • 2,091 posts
Posted 19 January 2015 - 09:36 PM
Sol, I have a Ctek charger you can borrow long term if you like? My car is a daily driver so it's not really used here. If I am deployed I will need it back however, but that isn't on the cards for a while. Let me know your thoughts.
#8 Sol
Sol
  • 122 posts
    My Car.
Posted 19 January 2015 - 09:37 PM
Thank's for your replies, it was just an idle thought & you've helped me realise it's not such a good idea. Best regards Sol.
#9 'Buchos'
'Buchos'
  • 792 posts
A friend bought a Lidl one at the weekend for his 944t and it looks like a nice bit of kit for the money.
Personally I've always used Optimate 4s, clever bit of kit and very rugged, even waterproof.
#10 VX220BOB
VX220BOB
  • 625 posts
Posted 19 January 2015 - 09:43 PM
I see that Lloyds are selling the one on ebay, I would not buy it from Lloyds as robbing bastards. If anyone is interested I will check tomorrow what I can sell that model for.
#11 VX220BOB
VX220BOB
  • 625 posts
Posted 19 January 2015 - 09:49 PM
#12 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 19 January 2015 - 10:00 PM
1/4 turn battery isolation switch. Job done.
#13 ghand
ghand
    Drunken lampposts only
  • 9,215 posts
    Oh and more whisky
Posted 20 January 2015 - 01:42 AM
If you battery is not fully charged for long periods you need a battery conditioner which has a monitoring processor if you want the thing to last a long time in good nick ready to use any time. When a battery is left not fully charged for long periods sulphate crystals build up on the plates. Conditioners have a pulse mode which removes the temporary sulphates a float mode, charge and trickle modes and so on all to keep the battery in good condition. A charger on a timer will work to an extent but you won't know if your over charging or under charging as it's not monitored but better than forgetting and leaving it on charge to cook or go flat and end up knackered Also a disconnected battery will still go flat slowly, depending on stored temperature, typically 5% per month if cold but in a warm place 15% or more. .
Edited by ghand, 20 January 2015 - 02:08 AM.
#14 Ormes
Ormes
  • 4,612 posts
Posted 20 January 2015 - 05:54 AM
As above... a convenient solution exists in the form of either a trickle charger or battery isolator. Removing a battery terminal is an option but you don't want to make it a pain to go on an unplanned ad-hoc drive as if you are anything like me it just won't happen! thumbsup
#15 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 20 January 2015 - 07:46 AM
I was told leaving the car standing for a long time regularly isn't good for it for a number of reasons. So much better to start it up, warm up and drive it around a bit.
#16 2-20
2-20
  • 1,317 posts
Posted 20 January 2015 - 09:28 AM
Don't know if it's good or not but i've a small charger (very Low amp.) connected to the cigarette lighter.
It's very easy to install
#17 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 20 January 2015 - 10:58 AM
I've tried the intermittent charging technique with time clocks and it's difficult to say if it were beneficial or not. I have a car that is sorned for 6 months, garaged and I just disconnect the battery and then periodically (every 6 weeks or so) reconnect and start the engine until it gets warm. This is more for getting the oil round the engine though than charging the battery. I usually wait for a string of warmish days to do this so I'm not cranking a really cold engine and I disconnect the coil and crank until i have some oil pressure before firing it up. This is on my old Stag. Suffice to say I always take a battery pack with me just in case :sleep:
#18 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 20 January 2015 - 05:29 PM
I was told it's better to start it and drive it rather than just let it idle as oil pressure will be highe. Is this rubbish? Agree it's best to circulate things. Just curious as I just drive mine. Couldn't stand not using it for 6 months.
#19 VX220BOB
VX220BOB
  • 625 posts
Posted 20 January 2015 - 05:58 PM
ctek xs 0.8 smart charger 56833 I can do this charger for £29.00 including postage (not Scotland or Ireland)I have no stock left and it will take about 10 days to get them.
#20 Smashf15c
Smashf15c
  • 25 posts
Posted 20 January 2015 - 11:53 PM
http://www.ebay.co.u...=item3aa04fd9bc I have several of these - they are very good!! Work well on my W211 Mercedes which is an electrics hog.... Cheers, Smash
