I've lazily started looking at piston ring gaps for the Z22 / saab engines. I would normally just gap them to spec and think nothing of it but with all the crank case pressure discussions recently I started to think more of it. I was reading that if the gap is too small it can cause issues that ultimately result in the gap becoming too large (Cant quite remember the ins and outs of that). Interestingly the wiseco spec is quite a tight gap at <20 thou but total seal spec theirs at min 25 thou. Thought I'd ask here what peoples thoughts are on this before I get filing.
Piston Ring Gaps
Posted 21 January 2015 - 08:45 AM
Posted 21 January 2015 - 09:26 AM
Edited by CHILL Gone DUTCH, 21 January 2015 - 09:32 AM.
Posted 21 January 2015 - 09:29 AM
with pcv working , oil scraper rings now able to work properly
Posted 21 January 2015 - 09:52 AM
I'm now taking steps to reduce/stop oil from getting into the inlet
Thats why I bought total seal rings. Gapless top FTW!
Posted 21 January 2015 - 10:47 AM
Posted 21 January 2015 - 10:53 AM
Posted 21 January 2015 - 10:59 AM
To my knowledge with too narrow a ring gap the ends will butt from thermal expansion and then your rings start excessively wear the cylinder walls...
Turbo or SC give more thermal load than NA and need more thermal expansion room.
Posted 21 January 2015 - 11:57 AM
I think Alanoo recommended larger ring gaps (30-40 thou) than Wiseco's recommended sizes. If Total Seal rings are such a good thing, why don't OEM's fit them as standard? Can't be any more expensive to manufacture something similar at OEM quantities than it is to manufacture "standard" style rings. There must surely be some potential downside for them to not do it.
Total seal type rings are usually a better grade material than OEM so they do cost a bit more. They do also cause their own issues in that, because they seal so well, you get a weird in/out pumping of crankcase pressure at idle.
