Help.....please 😃
immobiliser
15 replies to this topic
#1 Bigal1975
Bigal1975
  • 11 posts
Posted 16 February 2015 - 08:03 PM
Ok so have just bought a Tubby and it was all going well.....until it started getting dark and I went to put the lights on....car just stopped dead. I had to push the light switch again to turn off lights and then the car would start. Now if I turn on any of the internal lights, main bean, side lights or hazards car stops but indicators work fine? I've checked and replaced relays next to fuse box in front bonnet and when it happens there is a clicking noise...other symtoms are that the ignition lights go very faint until I turn the light switch off and then they go very bright again? Any help or pointers would be grateful?
#2 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 16 February 2015 - 08:18 PM
You mean operating the lights with the engine running makes the car cut out and you can't restart with them on? Sounds like it could be battery / alternator related if any significant draw is causing the car to cut out. Make sure it is charged up and the terminals are clean and tight. Does the same happen if you use the radio or any other accessory?
Edited by -Dab-of-Oppo-, 16 February 2015 - 08:25 PM.
#3 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 16 February 2015 - 08:24 PM
Poor battery earth would be my first guess Clean both battery connections then trace the earth side to the connection on the chasis
#4 Bigal1975
Bigal1975
  • 11 posts
Posted 16 February 2015 - 08:40 PM
Thanks will check the earth strap tomorrow. When the car is running all the brake lights, indicators, wipers etc work but when I try to use any of the switches such as side lights, low beam, hazard lights or even the small interior light in near the footwell the car dies? Also if I flash someone out? One note which adds to the mystery none of the headlights work? Now when I got home today I tried the lights one last time and it died - I then tried to restart her and it has no ignition lights and the car will turn over but not start?
#5 PaulCP
PaulCP
  • 6,066 posts
Posted 16 February 2015 - 08:44 PM
Can you test the battery? It's probably the first thing to test
#6 ant1
ant1
  • 298 posts
Posted 16 February 2015 - 08:48 PM
As Chris says, remove battery connection clean up with a bit of sandpaper and coppereaze do the same with eart connection and then charge battery. If still problems next thing I would do is check light connections, they corrode and cause all sorts of weird issues. If still not working get back on here.
#7 Bigal1975
Bigal1975
  • 11 posts
Posted 16 February 2015 - 08:54 PM
Guys as always thanks for the tips - Will check this out tomorrow and hopefully she will be back to normal
#8 stu8v
stu8v
  • 745 posts
Posted 16 February 2015 - 09:00 PM
Dont use copperslip/copperease.
Use vaseline, much better for the job.
#9 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 16 February 2015 - 09:23 PM
Dont use copperslip/copperease.   Use vaseline, much better for the job.
What job you on about that Vaseline is better for 😀
#10 stu8v
stu8v
  • 745 posts
Posted 16 February 2015 - 09:46 PM
Battery terminals/earth strap connections.
What else????
:sick:
#11 Judderman
Judderman
  • 869 posts
  • Interests:Shooting, Driving on Welsh Roads, Gaming Xbox/PC
Posted 17 February 2015 - 09:23 AM
check the battery voltage if possible whist the car is off and also when running to ensure your in the charging threshold. failing that goto rac.co.uk and order a replacement for peace of mind
#12 slindborg
Posted 17 February 2015 - 02:27 PM
does the car start strong every time? if so them its not the battery imho...
I reckon there is a short somewhere related to the internal switchgear, check out the wiring diagrams in the TIS as linked in the nooobie section.
#13 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 17 February 2015 - 09:23 PM
does the car start strong every time? if so them its not the battery imho...   I reckon there is a short somewhere related to the internal switchgear, check out the wiring diagrams in the TIS as linked in the nooobie section.
Ding.
#14 Bigal1975
Bigal1975
  • 11 posts
Posted 17 February 2015 - 10:52 PM
Car was turning over strongly but seemed like the immobilizer was stopping it - Traced the wires and found a bad earth and also a missing wire not plugged into the immobiliser......car is running perfect again. Thanks for all the help 😃
#15 Horace
Horace
  • 1,290 posts
Posted 18 February 2015 - 08:51 AM
Where is the immobiliser?  Are there individual wires plugged into it?
#16 siztenboots
  • 26,623 posts
Posted 18 February 2015 - 09:09 AM
don't buy from rac , they are now outrageously expensive, £100+
just buy a type 063 battery , < £30 ebay delivered, 4 year
http://www.ebay.co.u...=item418f1ab983
