Complete m32 6 speed conversion - £1700 (fitting can be arranged)
Gearbox has only done 5000 miles from new, supplied with 1st-5th gears from a corsa vxr, 6th gear from astra vxr
This gives excellent acceleration, similar ratios to a 4.55 F23
Rebuilt with brand new bearings
Helix clutch - less than 1k
Ttv custom flywheel - less than 1k
All mounts - less than 1k
Vockyd gear lever mechanism
Stage 3 or 4 SC engine - built from a saab b207 - £2350 (fitting can be arranged)
Built less than 1000 miles ago
GM Racing +0.5 oversized valves
Fully ported and polished saab cylinder head
CompCams Blower camshafts
Supertech double valve springs
Wiseco overbore forged low comp pistons 8.9:1, rebored block to suit.
Eagle steel rods
Balancer shaft delete
Balancer chain delete with Craig Davies electric water pump - but a standard pump can easily be fitted at no extra cost
Z22yh crank - this can be swapped for a polished z22se crank at no extra cost
Saab high capacity 7L sump
also have a load of powder coated parts to go with it
