Tire Width Ratio Front To Rear
Posted 26 February 2015 - 09:47 PM
Posted 27 February 2015 - 08:09 AM
Posted 27 February 2015 - 09:02 AM
Posted 27 February 2015 - 09:52 AM
I´m running 205/50-16" front and 235/40-17" rear on TD´s 7x16/8x17, ride height 123/128 with this geo
Total toe-out front: 0°03' Camber front left: 0.9° (max camber for my OEM uprights) Camber front right: 0.85° (max camber for my OEM uprights) Toe in rear left: 0°13' Toe in rear right: 0°13' Camber rear left: 2.5° Camber rear right: 2.6°
The car felt really good with this setup, very well balanced and got rid of most of the under steer.
Posted 27 February 2015 - 11:04 AM
The factory geo is designed to be more biased to understeer as this is "safer"
Go and get a decent geo, a more track focussed one should dial a lot of that out.
ETA: I have a 340R geo on mine with 195 fronts, 225 rears. It over steers much more readily than understeers suits me
Edited by TheRealVXed, 27 February 2015 - 11:05 AM.
Posted 27 February 2015 - 11:14 AM
Do you have to have modified uprights to achieve 340r geo?
I have a basic geo done already, but nowhere near as much camber on the front as the 340r, which is -1.5 right?
I currently have 195 front and 235 rear. I was going to go 205 front, but wasn't sure to stick to 235 rear or go 225. If I'm able to get more camber on standard uprights then I will do as well
Posted 27 February 2015 - 12:00 PM
http://wiki.seloc.org/a/Geo_Setups
340R road geo requires no special mods. 340R track might well do...
Posted 27 February 2015 - 01:37 PM
thanks for this... guess I will try and aim for the max. negative camber I can go to on the front on standard uprights with whoever ends up doing the geo
Posted 27 February 2015 - 06:01 PM
Matt Bentley https://www.facebook...acing?pnref=lhc will do you a good geo and advice on the best set up wheels tyres wise. He knows his Vx's and Elises. He's a good guy to chat to about it and is only an hour from you.
Steve at http://www.guglielmi...eguglielmi.html also does a good geo on these cars and is not to far also.
I have used both several times over the last ten years. Personally I'd go for Matt out of the two at the moment.
Posted 27 February 2015 - 10:13 PM
Posted 28 February 2015 - 08:41 AM
Posted 28 February 2015 - 10:05 AM
Posted 28 February 2015 - 10:15 AM
Any specialists in Hertfordshire that can do the geo?
Try doing it yourself (look online for video), it's quite easy, just takes a bit of time.
If you do it yourself, you can fiddle with settings back and forth with test drives in between and then come up with a geo that suits you, rather than what someone else infers you might want.
BTW, if you drive on road you will not be wanting max front negative camber (as your post mentions above), I wouldn't go above -0.5 degree camber on the front TBH, or you will get excessive inner barrel wear and also the car wont dig in reliably on variable road cambers (particularly in the wet).
Edited by Nev, 28 February 2015 - 10:19 AM.
Posted 28 February 2015 - 10:20 AM
Posted 01 March 2015 - 11:20 PM
