Still No Life.....even After Relay Swap
88 replies to this topic
#1 gingerjon
gingerjon
  • 587 posts
Posted 01 March 2015 - 11:24 AM
Morning all, You may have seen in my project thread a slight mishap with the relays.... Well after a few suggestions on here i swapped the relays from the front.....still nothing. Battery charged Red fuses under wiper motor checked Fuses checked Nothing....no dash life at all!! what am i missing? Help greatly appriciated :-)
#2 navx
navx
  • 369 posts
Posted 01 March 2015 - 12:21 PM
Are you getting power to the ecu?
#3 gingerjon
gingerjon
  • 587 posts
Posted 01 March 2015 - 12:23 PM
Dont think so. When I plug the battery in and connect it up....I dont even get the interior light! All terminals cleaned and just tried to use my other car a jump and nothing. So frustrating!
#4 JG
JG
  • 13,617 posts
Posted 01 March 2015 - 12:29 PM
Time to get the mulitmeter out, but i reckon its probably something as simple as dodgy connections. You need a new battery (jump leads often don't work properly) and the vx seems particularly sensitive to having a very good connection (so bolts on connectors done up tight)
#5 vocky
Posted 01 March 2015 - 03:44 PM
check the big fuses under the front windscreen, next to the wiper motor
#6 gingerjon
gingerjon
  • 587 posts
Posted 01 March 2015 - 04:40 PM
Two red fuses intact - thanks Vocky. JG - Multimeter is all thats left, borrowing one tomorrow so we shall see. All I want to do is hear the new exhaust!! :-)
#7 gingerjon
gingerjon
  • 587 posts
Posted 07 March 2015 - 04:17 PM
Does anyone want to buy a heap of plastic and metal? So, new relays installed, new battery bought, all fuses and big red ones triple checked........ Car is alive, finally dash lights, push the button......turns over but doesnt fire. When the 1st click of the key is done....no fuel pump whire? checked and pressed in and out the cut off switch multiple times. I have searched a million posts on here the only thing i havent changed currently is the brown relay. After the threads i am left with these options : Ecu Fuel pump itself The car was running fine before it stuttered, turned off and i found the relays assuming it was thoses. Turns out...... Heeeeeeeeeeeeeeeeeeeelllllllllllllllllllllllpppppppppppppppppppppp!!!!!!!
Edited by gingerjon, 07 March 2015 - 04:18 PM.
#8 vocky
Posted 07 March 2015 - 04:36 PM
link out the brown relay for a quick test, the live is the Brown (3mm) and the two circuits supplied have the Brown (2mm) and the Brown/Pink (2mm) wires
#9 gingerjon
gingerjon
  • 587 posts
Posted 07 March 2015 - 10:17 PM
Cheers Vocky, will give that a go tomorrow. So frustrating!! it was working fine 2 weeks ago!
#10 jakepeg
jakepeg
  • 1,168 posts
  • Interests:ALL SPORT
    Oh and now electric guitars and lots of noise
Posted 08 March 2015 - 08:58 AM
I had an ECU disconnect. Meant fuel pump whine, but just a click when turned engine. Ended up changing ECU as had corroded connectors. Expensive and undoes any re map But car starts!
#11 gingerjon
gingerjon
  • 587 posts
Posted 09 March 2015 - 11:01 PM
The ECU is all connected up, i unclipped and reconnected it to be sure. Not sure whether i linked the wire correctly on the brown relay as vocky says but still no fuel pump. The pump was working fine before the issue with the relays so it must be something electrical. Bloody car clearly does not want to go back on the road!!!
#12 techieboy
Posted 09 March 2015 - 11:19 PM
This is what I did to "hotwire" my pump when I wanted to drain the tank. Worked a treat.
ok, try this   Remove these relays and connect following pins to eachother in the relay holders Relay K16 (grey one on my car) - pin 1 - Brown/Grey Relay K18 (brown one on my car) - pin 3 - Brown (the one with 2x brown wires, one small, one large)   This should get +12v to the pump, the 0v is always connected
#13 vocky
Posted 10 March 2015 - 11:20 AM
you have checked the two fuses next to the boot relays ?
#14 gingerjon
gingerjon
  • 587 posts
Posted 10 March 2015 - 03:18 PM
Yep, both yellow fuses checked and replaced just in case too!
#15 CHILL Gone DUTCH
Posted 10 March 2015 - 03:34 PM
Are all the pins on relay plugs close enough to grip relay ?
#16 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 10 March 2015 - 03:43 PM
have you pushed the button on the fuel rail to see if there is any pressure?
#17 vocky
Posted 10 March 2015 - 04:26 PM
get a volt meter and start measuring where the power goes up to and then we can figure out why it's not completing the circuit  thumbsup
Edited by vocky, 10 March 2015 - 04:26 PM.
#18 rhoran00
rhoran00
  • 224 posts
Posted 10 March 2015 - 09:25 PM
The fact it stuttered sounds suspiciously like mine did when it broke - I'm in the process of getting a new ECU programmed. - Can you connect a fault code reader to it and get it to talk to the car? - Does the EML light up when you turn the ignition on? If the answer is no to both of the above, the only other option is to check your switched and permanent lives, and your earths to the ECU. If they're good, it's likely your ECU has given up the ghost
#19 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 11 March 2015 - 08:46 AM
And if it has, I may have a working spare ECU I'd be willing to sell.
#20 gingerjon
gingerjon
  • 587 posts
Posted 12 March 2015 - 09:54 PM
Thanks G, saturday will be spent with a Volt metre amd some bits of wire to see if i can work the issues out. Just want to get it running before it hits the bodyshop.....which is proving a pain in the arse!!
