[font="'Futura-Medium', Futura, 'Trebuchet MS', sans-serif;"]I used Renovo to put some life into the black soft top I bought, but I also had the original blue soft top which was in much better shape than the black one and I wasn’t using it simply because I thought the blue looked like a faded black top when on the car.[/font]
[font="'Futura-Medium', Futura, 'Trebuchet MS', sans-serif;"]So I hunted through some forums to see if ppl were changing soft top colours with Renovo and they were. The key is using quite an aggressive solvent to remove any added waterproofing. The cleaner I got smelled like nail varnish remover so was probably largely acetone based with a few other detergents to dilute it.[/font]
[font="'Futura-Medium', Futura, 'Trebuchet MS', sans-serif;"][/font]
[font="'Futura-Medium', Futura, 'Trebuchet MS', sans-serif;"]Once cleaned and allowed to dry the material had a very matt look to it. I applied two coats of Renovo Black, let it dry for a few days and applied another coat. The colour change could be seen after the first coat, I let the dye dry completely and moved on to waterproofing.[/font]
[font="'Futura-Medium', Futura, 'Trebuchet MS', sans-serif;"]I’d used waterproofing from AutoGlym etc in the past and thought it was a bit weak as the water still soaked into the fabric quite a bit when it rained. I’ve had much better results from Fabsil, which is for canvas tents. [/font]
[color=#000000;]This Fabsil isn’t dolphin friendly eco warrior water based nonsense its got paraffin and wax and all sorts of smelly chemicals so actually works. Two coats of Fabsil (which is less than 10% of this tin) applied with a paint brush quickly soaked into the material and after drying has a nice matt finish and water sits on top of it.[/color]
[color=#000000;][/color]
