Powder Coating Calipers
Posted 09 March 2015 - 08:48 PM
Posted 09 March 2015 - 11:04 PM
Posted 10 March 2015 - 12:57 PM
Posted 10 March 2015 - 07:00 PM
Posted 16 March 2015 - 10:46 PM
Posted 17 March 2015 - 09:51 AM
I was going to get mine powder coated last year and was advised by the powdercoaters not to as the shot blasting will destroy the seals and possibly the piston. Was more hassle than it was worth so decided to just clean and sand by hand then paint.
If you're getting them powder coated, you'd obviously have to remove the piston and seals beforehand and mask it all up.
If you're going to the trouble of removing the calipers, I'd replace the seals anyway. It's a 10 minute job and they're only a few quid.
Posted 22 March 2015 - 11:06 PM
Posted 23 March 2015 - 08:42 AM
There was a bit of a feature on Big Redd on one of the car restoration programmes - Car SOS I think. They do fully strip the caliper and it looked as though they really knew what they were doing.
Posted 23 March 2015 - 09:18 AM
It's a piece of p*ss for regular piston calipers (our rear calipers aren't 'regular' calipers), it certainly doesn't need a TV program to do it.
- Start by soaking the new seals in brake fluid.
- Remove the caliper and take the pads out
- Using a small flat head screwdriver, remove the dust caps
- Put a block of wood between the pistons and press the brake pedal to force the pistons out
- If required, using 2 flat head screwdrivers, lever the piston out using the groove in the piston for the dust caps (be careful not to damage the piston)
- Again using a small flat head screwdriver, flick out the piston seals.
- Rebuilding is just a reversal of the above
- Bleed the brakes before you bolt the caliper back to the hub, making sure to turn the caliper upside down and tap it to remove any air.
