Part 1
[font="'times new roman';"]Just finished installing the above, and am very pleased with the result. Even under hard acceleration and usage the inlet temperatures never increase to more than 3 deg C above ambient.[/font]
[font="'times new roman';"]Used the guide on the forum and instructions with the kit for the majority of the installation. However, made a departure when running and fixing the 22 mm rubber cooling pipes.[/font]
[font="'times new roman';"]The mounting of the charge cooler radiator under the main engine radiator, was by four spacers. This produced a gap a around the radiators which could let the cooling air escape and cut down on the efficiency of the system.[/font]
[font="'times new roman';"]Used some left over ‘Builders walling’ insulation from my house extension to stick on and close the gaps.[/font]
[font="'times new roman';"][/font]
[font="'times new roman';"]To make the running of the 22 mm rubber cooling pipes through the drivers side sill easier, I cut a 104 mm hole at either end of the sill with a hole saw, and installed marine grade plastic, bulk head, apertures (these are half a turn to close and have rubber ‘O’ ring seals). This had many advantages, least not the easy access by hand of the pipes and drilling of the holes in the foam supports, plus easy of access to the worm drive clip at the base of the charge cooler.[/font]
[font="'times new roman';"]Rear one.[/font]
[font="'times new roman';"][font="'times new roman';"][/font][/font]
