Struggle To Get Bottom Intercooler Hose Off
14 replies to this topic
#1 Andrpers
Andrpers
  • 97 posts
  • Interests:Cars
Posted 29 March 2015 - 07:03 PM
Any tips or tricks?
#2 Nev
Posted 29 March 2015 - 07:14 PM
Get a child with small hands in there. It can be tough going.
#3 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 29 March 2015 - 07:16 PM
Is it the access you are struggling with or the stiffness of removal? If it is anything like mine the rubber may have perished a bit and kinda fused / melted itself against the metal collar slightly. I prised up the edge of the pipe and injected a lubricant up underneath and then worked it around as best I could which eventually helped it to be pulled off.
Edited by -Dab-of-Oppo-, 29 March 2015 - 07:17 PM.
#4 Andrpers
Andrpers
  • 97 posts
  • Interests:Cars
Posted 29 March 2015 - 07:18 PM
:) .. I get my hand(s) in and can pull pretty hard but it refuses to move.
#5 Andrpers
Andrpers
  • 97 posts
  • Interests:Cars
Posted 29 March 2015 - 07:22 PM
Access is as good as I gets. Got the turbo ear, wheel arch and bottom tray removed. "Sadly" mine is in perfect condition so very hard to get anything between the hose and the pipe.
#6 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 29 March 2015 - 07:37 PM
Different hose but this what I did with mine. Used a syringe with oil in pushed up under the edge you only need to prise a very small amount up with a flat head screwdriver to get a bit underneath. A little goes a long way and it helped a lot with sliding it off. Also squeeze as close to the end as you can (use adjustable pliers or G clamp) and twist side to side as you pull and it should help shuffle it off. Failing that cut the bastard thing off (small slit on top of the connector to start) and either hope you've got enough slack to rejoin it or have a spare at the ready.
Edited by -Dab-of-Oppo-, 29 March 2015 - 07:40 PM.
#7 VX220BOB
VX220BOB
  • 625 posts
Posted 29 March 2015 - 07:41 PM
Hot water will soften/expand the hose.
#8 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 29 March 2015 - 07:42 PM
:yeahthat: Also if you can see if it is any easier having just driven / run the car.
#9 Andrpers
Andrpers
  • 97 posts
  • Interests:Cars
Posted 29 March 2015 - 08:03 PM
:yeahthat:
Thats not an option, the car is in bits in the garage :) But I will try warming up the pipe.
I will try that or a hair dryer...
Thanks, to cut will be my last resort :P
#10 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 29 March 2015 - 10:22 PM
Try this:
[font="'times new roman';"]Posted Image[/font]
[font="'times new roman';"]Makes removal very easy :) [/font]
#11 Ormes
Ormes
  • 4,612 posts
Posted 30 March 2015 - 07:29 AM
Maybe try one of those hook shaped scraping tools?
#12 Andrpers
Andrpers
  • 97 posts
  • Interests:Cars
Posted 30 March 2015 - 06:07 PM
Try this:
That's cheating :P
I will see what I can find :)
#13 Ormes
Ormes
  • 4,612 posts
Posted 30 March 2015 - 06:33 PM
...called a "pick and hook set" apparently :)
#14 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 30 March 2015 - 06:39 PM
I would of gone more with a trim removal tool as they'll likely just bend and or poke a hole in the rubber.
Edited by -Dab-of-Oppo-, 30 March 2015 - 06:40 PM.
#15 Ormes
Ormes
  • 4,612 posts
Posted 30 March 2015 - 06:45 PM
Never seen them before... (off to machinemart.co.uk :))
