2.5'' Vxt Sports Cat Options
Posted 29 March 2015 - 09:02 PM
Posted 29 March 2015 - 09:46 PM
Posted 29 March 2015 - 09:51 PM
Posted 29 March 2015 - 09:58 PM
Posted 30 March 2015 - 06:29 AM
Tubular from MMG?
Posted 30 March 2015 - 10:04 AM
Posted 30 March 2015 - 10:56 AM
Posted 30 March 2015 - 02:05 PM
Posted 30 March 2015 - 09:08 PM
Do you get through MOT emissions with a 100 cell? Who supplied you with just the cat section on its own? I've found this site that lists the sections for sale seperatly and it's coming out at a still fairly steep £591 with delivery. So it does look like there is only the two options for a complete ready to fit 2.5'' solution? I did read about a reasonably priced Blue Flame one but they seem to have disapeared / be unavailable now.I have a larini/ miltek combo, larini back box, miltek down pipe and miltek 100 cell cat, can't recall the price of the cat off the top of my head, although pretty sure it was cheaper than the larini.
Posted 30 March 2015 - 09:11 PM
Apart from it being shiny and new I don't think there is any real benefit in getting that over just working with the OEM pipe is there? Same layout and diameter so it should be just as easy to cut the standard cat out and replace with a similar sized high flow.? Even if it means adding in another short stretch of pipe to bring it back up to the same length. If I can get hold of a used OEM cat section (I'll place a wanted post) I think I'm going to go that route, so Toyosports front pipe > OEM main pipe with 200 cpi cat welded in > Larini back box. Should work well shouldn't it? Anyone got any particular recommendation for a weld in universal sports cat or are they all pretty much as good as each other?Buy the larini decat and you can get a weld in 200 cel cat for about £80.
Posted 30 March 2015 - 09:52 PM
Edited by pete-r, 30 March 2015 - 09:53 PM.
Posted 30 March 2015 - 09:57 PM
as above, my larini full system was only 11kg
this is over half the weight of the original vxt system
Posted 30 March 2015 - 10:55 PM
Never had any problems with m.o.t and I've had the cat for good few years, I think I ordered the cat and down pipe separately from Thorney Motorsport, you're right though I'm sure the cat was around £500 so not exactly cheap.Do you get through MOT emissions with a 100 cell? Who supplied you with just the cat section on its own? I've found this site that lists the sections for sale seperatly and it's coming out at a still fairly steep £591 with delivery. So it does look like there is only the two options for a complete ready to fit 2.5'' solution? I did read about a reasonably priced Blue Flame one but they seem to have disapeared / be unavailable now.I have a larini/ miltek combo, larini back box, miltek down pipe and miltek 100 cell cat, can't recall the price of the cat off the top of my head, although pretty sure it was cheaper than the larini.
