Alternative L/r Mounts
20 replies to this topic
#1 myles
myles
    Sausagefest
  • 2,093 posts
Posted 09 April 2015 - 09:06 AM
Anybody have any experience of these - http://www.regelin-p...html?opt={18}50 At £80 odd including delivery they must be worth a punt if they don't tear?
#2 smiley
Posted 09 April 2015 - 09:19 AM
Search ebay for generic anti vibration mounts to get them for cheaps.
Like this (only bigger)
http://www.ebay.co.u...=item2c927b10ed
Just measured, and oem is 65mm high (the damping part), thread is M10, and both sides thread sticks out 25mm.
Edited by smiley, 09 April 2015 - 09:30 AM.
#3 Exmantaa
Posted 09 April 2015 - 09:24 AM
Also called silent blocks...
#4 fezzasus
Posted 09 April 2015 - 09:27 AM
Don't trust those at all, same design couldn't even hold my ABS pump or airbox in place. I wouldn't want them to look after an engine.
If I had to change my engine mounts again, I would move to VibraTechnics. They're more expensive, but I can't imagine needing to change them ever again.
http://www.vibra-tec...vx220_speedster
Edit: VX220 parts sell them for £101 ea.
Edited by fezzasus, 09 April 2015 - 09:31 AM.
#5 smiley
Posted 09 April 2015 - 09:32 AM
I understand the waryness, but Regelin is considered an authority in speedster germany, and there have been no complaints on these yet. (well at least not online)
The key question here being how generic, or how special they are.
#6 siztenboots
Posted 09 April 2015 - 09:35 AM
could just as well stick some threaded bar in a silicone mold
#7 smiley
Posted 09 April 2015 - 09:47 AM
This should be close enough.
http://www.rc-force....M10-R-70-/-H-70
#8 techieboy
Posted 09 April 2015 - 11:28 AM
No way will those generic bobbins be up to the job. They can't even space/support the diffuser for more than a handful of miles. The rubber they use is nowhere near hard enough and I doubt the metal end plates can support enough weight without being deformed and pressed into the rubber.
ETA: That's not a comment on Regelin's mounts which may or may not be spot on.
Edited by techieboy, 09 April 2015 - 11:40 AM.
#9 CocoPops
CocoPops
  • 17,182 posts
Posted 09 April 2015 - 11:30 AM
If only someone was selling an OEM mount? :lol: :rolleyes:
#10 Nev
Posted 09 April 2015 - 12:06 PM
What's the Shore number on the OEM mounts?
#11 smiley
Posted 09 April 2015 - 12:11 PM
You hear the verdict Miles.
Please buy one from Regelin, and cut it open so we can see the unicorn magic inside :sleep:
Edited by smiley, 09 April 2015 - 12:11 PM.
#12 myles
myles
    Sausagefest
  • 2,093 posts
Posted 09 April 2015 - 12:41 PM
Regelin mounts it is then. I have a set of the Powerflex front and rear inserts to fit at the same time, which may or may not be perceived as cheating!
#13 techieboy
Posted 09 April 2015 - 12:46 PM
Probably fit better than the VibraTechnics ones do, anyway.
#14 2-20
2-20
  • 1,317 posts
Posted 10 April 2015 - 08:31 AM
Right !
I had to blend out an area of the alloy hat otherwise i would have introduce nasty preloads in the LHS fitting.
Mine is a NA but on Turbo car check the RHS.
#15 fezzasus
Posted 10 April 2015 - 09:58 AM
Has anyone discussed this with VibraTechnics? I assume they are milled in small batches, so should be very little work to modify the design.
#16 2-20
2-20
  • 1,317 posts
Posted 10 April 2015 - 11:25 AM
I've been told that they now provide large washers (one per side) to have a gap between the fitting and the mount.
So it seems that they are aware .
#17 vocky
Posted 10 April 2015 - 01:19 PM
just fit the uprated inserts to the front and rear mounts, then add a pair of standard side mounts and never worry about them again  thumbsup
#18 Luke84
Luke84
  • 870 posts
Posted 10 April 2015 - 01:57 PM
I can vouch for this, the noise of a tat diffuser hitting and then scraping along Tarmac at some mph will stick with me for a while!
#19 myles
myles
    Sausagefest
  • 2,093 posts
Posted 10 April 2015 - 03:08 PM
Sounds hellish Luke. Were they the same as the Regelin items I linked to?
#20 Luke84
Luke84
  • 870 posts
Posted 11 April 2015 - 09:25 AM
Not quite they were a male/female version if the eBay link below yours. I guess they would work much better under compression than tension as they are far less likely to shear like mine did. Those regelin ones are massive though, they've got a pretty good reputation for speedster stuff so I can't imagine there would be an issue with them.
